Home > Forums > General Forums > System Analysis
Hydraulic external gear motor pressure drop
Old   December 20, 2018, 10:38
Default Hydraulic external gear motor pressure drop
Mark
novelfluids is on a distinguished road
I have several experimental datasets for external gear motors which indicate a linear relationship between the pressure drop and the rotational speed of the machine in the unloaded state. Datasheet values from major gear motor manufacturers seem to further support this data.
I am struggling to understand the fluids dynamics behind this linear trend. As far as I can see the pressure across a gear motor in the unloaded state should only be a function of the machine's losses. I can only see two loss mechanisms in operation 1) Internal friction which I would expect to require an approximately constant torque to overcome regardless of speed (once you are above the critical speed for hydrodynamic lubrication) and 2) viscous losses which I would expect to be proportional to the square of the mean fluid velocity and hence the motor's rotational speed. Summed together this should give me a quadratic relationship between motor unloading speed and pressure drop but there is a clear linear trend.
Can anyone enlighten me?
Mark
novelfluids is offline   Reply With Quote
gear, hydraulic, motor
Pressure Drop in Hydraulic Valve #2 UdoUebel STAR-CCM+ 0 February 17, 2016 05:26
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 02:40
External Gear Pump interawe ANSYS Meshing & Geometry 0 April 14, 2009 18:55
3D External Gear Pump Mustafa Ayad FLUENT 1 January 26, 2009 10:55
Hydraulic diameter for external flow. pah FLUENT 0 July 20, 2005 05:27
