Home > Forums > General Forums > System Analysis
sod's test by lax-friedrichs method
Old   December 15, 2018, 08:14
Default sod's test by lax-friedrichs method
mend4x is on a distinguished road
hi everyone!
I've been solving Sod's Shock Tube Problem with Lax-Friedrichs method on C++. I use this link as the main one. But I face the problem with defining entropy. I found
  • density,
  • velocity,
  • pressure,
  • Mach number,
  • speed of sound;
but entropy fails. Can anyone help me with it?
P.S. I attached the archive with code and graphs
mend4x is offline   Reply With Quote
Old   December 20, 2018, 14:40
Eifoehn4's Avatar
Eifoehn4 is on a distinguished road
Dear mend4x,
Entropy in general is a value, which is calculated via integral relation. This means, you have to know the reference state to compare your solution. Nevertheless you can compare the difference between two neighboor cells or you can shift your solution to the correct level.
You should also check if the reference solution uses Entropy per mass or Entropy per volume.
If your calculation variables match the reference, then the problem is only a post-processing issue.
Check out my side project:
A multiphysics discontinuous Galerkin framework: Youtube, Gitlab.
Eifoehn4 is offline   Reply With Quote
Old   October 18, 2019, 01:58
set::set() is on a distinguished road
Hello, thanks for sharing. I've used your code to do some test of performance with c++. I would like to suggest to you two things.
First is. The code is far from optimal because you are doing things in consecutive loops that take the same limits. For example here:
for (int i = 0; i < nx; i++) {
x[i] = x0 + i * dx;
if (x[i] < 0) {
ro[i] = 1.;
u[i] = .0;
p[i] = 100000.;
} else if (x[i] >= 0) {
ro[i] = .125;
u[i] = .0;
p[i] = 10000.;
You can do simply:
x[i] = x0 + i * dx;
if (x[i] < 0) {
ro[i] = 1.;
u[i] = .0;
p[i] = 100000.;
ro[i] = .125;
u[i] = .0;
p[i] = 10000.;
But this things are minor issues, the real problem is you can't rely in your code since you don't initialize variables. I have done some memory test and some arrays like this V[nx][3], Vn[nx][3], F[nx][3] take eventually random values. Since your are passing this Vn[0][j] and Vn[nx][j] to V[0][j] and V[nx][j] without assign any value to Vn your code will give you unexpected results. You can simply initialize to some value by writing this simple line:
double Vn[nx][3]{0};
thanks for sharing, cheers!
set::set() is offline   Reply With Quote
euler equation, lax-friedrichs, riemman, sod shock tube
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
SIMPLEC Method meshkati Main CFD Forum 6 November 19, 2009 01:48
test cases Maciej Matyka Main CFD Forum 3 November 24, 2004 09:27
time accuracy test nat Main CFD Forum 0 April 2, 2003 00:24
