Home > Forums > General Forums > System Analysis
Gas Jet Analysis
Old   June 25, 2018, 06:27
Default Gas Jet Analysis
Sridhar Sahoo
SRI28337 is on a distinguished road
Using Ansys Forte, I was simulating gas injection in a constant volume chamber. Where the gas is methane and the ambient gas present inside the chamber as air. I designed one 1 mm dia nozzle, where ch4 is injected at a total pressure of 20bar with turbulence parameter as turbulence kinetic energy 10,000cm2/sec2 and turbulence length scale 1cm. Assuming isoentropic temperature boundary condition.
I got higher axial and too high radial penetration, with comparison to experimental results.
I dont know where i am doing wrong ?
SRI28337 is offline   Reply With Quote
Old   September 6, 2019, 11:12
sahil
sahilg is on a distinguished road
hello guys,
the answer of this question is given below
We conducted a three-dimensional fluid dynamics analysis of the solid-gas mixed-phase flow from a top blowing lance by considering the application of powder ...
thanks.
sahilg is offline   Reply With Quote
gas jet, injection, turbulence kinetic enregy, turbulence length scale
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Free Shear flow: Jet simulation result analysis samurai_01 Main CFD Forum 1 July 1, 2014 11:15
Multiphase flow (Comp. jet of gas into liquid) Sarah FLUENT 1 October 7, 2013 22:39
Cold FLow analysis in Gas Turbine..Help Needed juzer_700 FLUENT 8 September 30, 2013 03:47
CFD Analysis - Combustion in Gas Turbine Engine juzer_700 Main CFD Forum 0 April 19, 2012 03:10
