February 18, 2018, 02:51 |
Flow on the wall and boundary conditions
Sergey
Rep Power: 8 |
I'm new in OpenFOAM and I'm trying to simulate injection of helium into surrounding air (N2/O2/H2O = 0.77/0.225/0.005) with surface (wall) which is located at distance 3 cm from the helium's outlet and perpendicular to the helium's flow. Firstly, I simulated helium ejecting into air without the wall. In order to do that I used reactingFoam without combustion and chemical reactions. But I don't know what kind of boundary condition should I use then I want to add the wall. I want the helium's flow to flow along the wall, so I should make normal component of the flow's speed equal zero. How to do that? |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
