Home > Forums > General Forums > System Analysis
Increase in flow rate decrease in Outlet pressure.
Old   November 2, 2017, 10:01
Default Increase in flow rate decrease in Outlet pressure.
North Carolina
trovilb1 is on a distinguished road
I've run into an interesting problem with testing a heater core system for a vehicle. I instrumented the system(instrumentation included inlet/oulet pressure, thermo couples, and flow meters). There is only one fluid path in this heater core and no leaks were observed. As i increased fluid flow through the system the pressure differential did increase, but what confused me was the outlet pressure dropped. i would assume the outlet pressure would increase with the increase or stay constant. I can't seem to explain why it would decrease. They heater core was a double pass so it has a high restriction. I don't know if that could account for outlet pressure decreasing with an increase in flow rate. assume all instrumentation is operating correctly.
trovilb1 is offline   Reply With Quote
Old   December 5, 2017, 08:22
Ravindra Shende
Ravindra Shende is on a distinguished road
I know this is a late reply, but still....
Yes, you are right in thinking that the outlet pressure is decreasing because of the high restriction in the heater core.
This is because the pressure drop in a system is proportional to the square of the velocity.
So, as you increase the fluid flow, the velocity will increase linearly but the pressure drop will increase parabolically.
Ravindra Shende is offline   Reply With Quote
flow rate, pressure drop
Pressure outlet as a function of the flow rate (windkessel) Trev0r CFX 10 October 23, 2023 17:50
Reversed flow using Pressure inlet and pressure outlet didimad FLUENT 0 March 14, 2015 06:38
Gate valve flow simulations... nikesh FloEFD, FloWorks & FloTHERM 5 January 28, 2014 02:31
Guessing the static pressure needed to produce flow rate jpo FLUENT 0 June 22, 2009 13:53
pressure outlet BC for incompressible flow khaiching Main CFD Forum 6 October 15, 2005 03:58
