Home > Forums > General Forums > System Analysis
Finite volume method
Old   October 13, 2017, 18:07
Post Finite volume method
Merouane KEROUAZ
Merouaneker is on a distinguished road
Hello everybody,
Can you help me to solve the hyperbolic heat conduction equation ?
Actually, I have problem in initial conditions, I don't know how to use it :
T(x,0)=0 and dT(x,0)/dt=0
The equation is :
d²T/dt²+2dT/dt+d²T/dx²=0
Thank you .
Merouaneker is offline   Reply With Quote
Old   October 24, 2017, 00:49
Ziga
Zigec is on a distinguished road
Send a message via Skype™ to Zigec
You need to integrate your equation two times, with this you will get additional to the final equation two constants (lets call them A and B). After this you use your 2 boundary conditions to solve the yet unknown constants.
After the first integration you get a first order DE in which you insert your second boundary dT() and calculate the first constant.
Then you insert in the final equation (after two interpolations) the now known first constant and your first boundary condition T(). With this you can than calculate your second constant.
The final equation should look something like that:
[equation] + Ax + B
Zigec is offline   Reply With Quote
equation, heat conduction, hyperbolic, initial conditions.
The aspect ratio of the volume elements in Finite Volume Method CharlieTan84 Main CFD Forum 3 August 28, 2012 03:34
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
ALE in finite volume method littlelz Main CFD Forum 5 June 21, 2003 13:50
finite volume method for CFD analysis of 2D blunt body Aditya Vaze Main CFD Forum 1 January 19, 2000 14:55
