Home > Forums > General Forums > System Analysis
Heat Transfer Co-efficient
Old   August 16, 2017, 01:43
Post Heat Transfer Co-efficient
patilsachin is on a distinguished road
Hello everyone,
Can anyone tell me on what factors does the heat transfer co-efficient depend upon.
I am trying to do simulate two types of Quenching
1. Quenching of High Carbon Steel in an Oil Bath
2. Quenching of High Carbon Steel in a water jet (mixed with polymers)
I need to find the HTC in each case. Hence I wanted to know what are all the parameters (however minuscule or general) , the HTC depends upon.
Any leads would be highly appreciated.
Thank YOu
patilsachin is offline   Reply With Quote
Old   August 25, 2017, 05:28
Kristjan
krikre is on a distinguished road
There might be some experimental research papers dealing with the quenching you describe. Try to google that out.
You might already know this, but the HTC values are likely strongly dependent on the flow velocity at the fluid-solid interface. Bubble formation would likely have a strong insulating effect. Other than that the fluid heat capacity could play a role.
krikre is offline   Reply With Quote
Old   October 6, 2017, 20:33
Nurzhan
Nurzhan is on a distinguished road
Originally Posted by patilsachin View Post
Hello everyone,
Thank YOu
In addition to the above, heat transfer coefficient also depends on a surface temperature of the solid material. This temperature would affect the fluid's viscosity and hence will govern the fluid flow.
Generally, a heat transfer coefficient should be determined experimentally. Theoretically, knowing the surface temperature, T_s, and the temperature of the fluid measured prior to quenching, T_f, heat transfer coefficient can be determined by solving the following equation:
\frac{\partial \rho C_p T}{\partial t} = \frac{hA}{V}(T_s - T_f),
where A is the surface temperature of the solid and V is the volume of the solid.
Nurzhan is offline   Reply With Quote
convection, heat tranfer coefficient
Heat transfer using all modes bhups45 FLUENT 0 June 19, 2016 08:02
Heat Transfer in Porous Medium eryan STAR-CD 0 September 28, 2010 14:14
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 19:53
Question on heat transfer coefficient!!! Benny FLUENT 7 June 7, 2005 10:25
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
