Rep Power: 9 ![]() |
Hey everyone, this is my first question and i hope to do everything right (especially posting into the right forum). So my problem is the following. I have a given energy function E(k) (in my case a modified von Karman). From this I create a velocity field on an NxN Grid on my Computer. To check if I did everything right, I calculate again the energy function from the velocity field that i have created. As a second check I would like to compare the velocity probability density function (pdf), which I can easily get as a normed histogram from my velocity field, to an analytical derived pdf. My problem now is, that I do not know how to calculate the pdf from the energy function I have. I googled and read in some books but did not find any guidance. Does anyone have advice ? Thank you guys a lot
energy function, pdf, velocity |
A new wall function based on the velocity field----strange result | huangxianbei | OpenFOAM Programming & Development | 6 | September 30, 2015 07:52 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
