January 10, 2017, 01:28 |
Heat transfer in molten metals
Gareth
Hi all,
I am currently working on a heat transfer problem for a galvanizing process. I would like to determine the time it takes wire to saturate to the temperature of the molten lead it is pulled through. The problem I have is in calculating the heat transfer coefficient h. The wire is pulled slowly (<1m/s) through the molten lead such that the flow is axially along the wire (horizontal cylinder with parallel flow). I have attempted to approximate h by assuming the Nu relation for flow of liquid metal over a flat plate (Nu = 0.564*Pr^0.5*Re^0.5). However i'm unsure on the validity of this assumption. Is there any relation for Nusselt number or heat transfer coefficient for laminar flow axially over a cylinder? I can only seem to find correlations for flow across a cylinder (e.g.: In a tube bank system). I'm at a complete loss at the moment. Any help would be greatly appreciated. Thanks. Last edited by Gareth85; January 16, 2017 at 09:23. Reason: Added clarity to question |
heat transfer, heat transfer coefficient, molten metal |
How To Calculate Average Heat Transfer Coefficient in CFD-Post? | Shomaz ul Haq | CFX | 16 | November 24, 2019 18:57 |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
Question about heat transfer simulation | Anna Tian | Main CFD Forum | 0 | January 25, 2013 18:53 |
Heat Transfer in Porous Medium | eryan | STAR-CD | 0 | September 28, 2010 13:14 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
