Home > Forums > General Forums > System Analysis
the effect shaft size has on vorticity
Old   July 14, 2016, 11:13
Unhappy the effect shaft size has on vorticity
david glynn
davd4696@gmail.com is on a distinguished road
Hi Folks,
apologise if this is the wrong place to put my question but I would be grateful if some of you could lend me your expertise.
I have currently trying to design a central shaft for a vertical axis tidal turbine, I am happy with the calculations for deflection and stress etc. however what I am not able to evaluate is the effect my chosen shaft diameter will have on the downstream blades via vorticity.
I am aware that the larger my shaft the larger my Reynolds number will be and this has a direct relationship with turbulence, I have also come across that the Strouhal number has a big contribution to play here and the critical St of 0.21
the approach I am considering using is takingthe maximum design RPM of the turbine converting to Hertz and using it as my oscillation frequency in the Strouhal equation and playing around with the d value? or is this ludicrous
if anyone has an experience in this analysis please share.
Thanks in advance,
Dave
davd4696@gmail.com is offline   Reply With Quote
fluids, reynolds number, shaft dynamics, strouhal number, vorticity
[blockMesh] edges not aligned with or perpendicular to non-empty directions ynos OpenFOAM Meshing & Mesh Conversion 6 March 26, 2020 16:02
Hydrocyclone simulation and catalogue size problem alexandre.david CFX 8 May 15, 2015 09:40
[Gmsh] Gmsh and element size factor msarkar OpenFOAM Meshing & Mesh Conversion 0 May 2, 2011 03:55
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
OpenFOAM 13 AMD quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 1 November 11, 2007 00:23
