Home > Forums > General Forums > System Analysis
Mass conservation problem, Finite Element
Old   September 19, 2015, 21:09
Default Mass conservation problem, Finite Element
Imtiaz
iahmedimtiaz is on a distinguished road
In my system the geometry contains one impeller & two concentric cylinders which generates an annular section where the flow goes down and internal section where the flow moves up due to the impeller suction effect.
I have simulated the flow dynamics using one "Finite Element software package" .
Now, I am calculating the mass flow rate by "surface integral" at middle cut section of the object. There are two mass flow rates. Flow goes down by annuls section and comes up by inside cylinder.
Both flow rate supposed to be same based on mass conservation law.
But I am getting significant difference specially at high rpm. Is this because of finite element method? Please advice.
iahmedimtiaz is offline   Reply With Quote
finite element method, mass conservation
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
combustion problem mcnair CFX 9 March 22, 2011 15:06
Problem of mass conservation in multispecies flow in porous media and T° gradient pilou FLUENT 0 January 31, 2011 09:19
Total mass flow/flux through a plane problem nwalters FLUENT 1 December 18, 2010 13:23
Mass conservation problem in mixing tank multiphase simulation rockewan FLUENT 0 April 6, 2010 13:34
