Home > Forums > General Forums > System Analysis
Gas tank discharging
Old   September 5, 2015, 05:49
Default Gas tank discharging
marian.nedelcu is on a distinguished road
I think the gas tank discharging were highly studied. But I am still confused when I count the number of equations and the number of unknowns.
Problem: Having known pressure and temperature of gas into the tank find their variation versus time if the tank discharges in atmosphere through a small hole.
Equations:
1. Mass conservation (continuity equation)
2. Momentum conservation( Euler or Bernoulli equation)
3. Energy conservation
4. Gas state equation
Unknowns:
3 parameters inside the tank: pressure temperature and density
3 parameters at the hole; velocity, temperature and density
Note:
1. the pressure at hole is assumed to be equal with atmospheric pressure
2. The state equation is counted twice; inside the tank and at the hole
Conclusion; 5 equation and 6 unknowns
Could you tell me what I am misiing?
marian.nedelcu is offline   Reply With Quote
Old   July 12, 2016, 14:32
Default Equation for the discharge from the orifice
Maryam
Persia is on a distinguished road
I think you are missing the equation which correlates the orifice (hole) discharge rate to the tank pressure.
Persia is offline   Reply With Quote
compressible flow, discharge coefficient, discharging, one dimensional flow
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Need Help! High pressure Gas discharge from tank to tank through a pipe superarthur86 FLUENT 2 June 16, 2017 11:22
error message cuteapathy CFX 14 March 20, 2012 07:45
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
