July 4, 2015, 04:24 |
Cooling cube in a room
Major
Hi all,
Let us suppose that a small cube (a = 10 cm) made of gold is placed at the ground supposed to be a semi-infinite plane medium made of wood. The small cube is enclosed (left, right and top) by a large cubic box (L = 2 m) filled with air and made of plaster. This configuration represents a small cube placed at the ground of a room. The initial temperature of the cube (Tic = 60°C) is known, the initial temperature of air in the box is known (Tia = 20°C) and also all the relevant parameters of the system (calorific capacities, heat transfer coefficients...). I would like to calculate the temperature of the center of the cube Tc(t) and obtain the 3D velocity field as a function of the time by taken into account : - the thermal transfer between the cube and the air (convection...) - the thermal transfer between the bottom of the cube and the surface of the ground on which it is placed (conduction by contact...) - the thermal transfer by radiation (cube and sides of the box). In this problem, the boundaries of the large box are supposed isolated (q = 0 due to the thermal isolation of the room). Up to now, I solved the problem only when the box is supposed infinite with a small cube that floats in air (cooling of a cube embedded in air) but how to set OpenFoam to solve the problem above ? In particular to take into account the surface on which the cube is posed ? Have you a similar model to proposed me ? Thank you for your help. |
[snappyHexMesh] snappyHexMesh on sharp corners (cube) | Regis_ | OpenFOAM Meshing & Mesh Conversion | 0 | June 5, 2015 00:47 |
Cooling coil simulation in room | hanqiang | Phoenics | 1 | September 23, 2014 10:52 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 07:29 |
Salome and Code Saturne simulation of simple room and objects | cristian.ocnarescu | Main CFD Forum | 0 | June 21, 2010 11:19 |
Passive cooling system for batch reactor | Darek | Main CFD Forum | 0 | September 30, 2003 06:06 |
