1D heat flow through rod with changing thermal diffusivity |
December 2, 2014, 12:21 |
Carl Johan
Hello! I'm comparatively new to this whole world of CFD. I've looked at the examples in "12 Steps to navier stokes" and would say I understand that okay.
(http://lorenabarba.com/blog/cfd-pyth...navier-stokes/) I've now gone back to 1D, and I'm trying to do some computations on the 1D heat equation: http://en.wikipedia.org/wiki/Heat_equation My case is for example this: I've got a rod that's insulated around the sides such that the 1D case makes sense to use, the right side of the rod is connected to something such that the temperature is a constant T_1 and the left side a constant T_2. (similar to step 3 in the link) If the thermal diffusivity is constant throught the rod, then this problem is something I can find solved on the internet everywhere (using a finite difference scheme). But what if the thermal diffusivity is nonuniform, for instance, if the rod is splitted up into 2 equally big parts but with a different diffusivity for each part (ie, made of different materials). Can I then simply make the thermal diffusivity a function of x_i in the equation? Ie, write: du/dt = a(x)*(d^2 u/dx^2) instead of du/dt = a*(d^2 u/dx^2) If yes, why? if no, why not ? |
December 7, 2014, 21:40 |
#2 | |
Troy Snyder
Rep Power: 19 |
If you solve the problem numerically, the variable conductivity does not present a problem. You simply discretize the conductivity. For example, a finite difference discretization of the diffusion term would be: d/dx ( a*du/dx ) = ( (a*du/dx)_i+1 - (a*du/dx)_i ) / ( x_i+1 - x_i ) = ... a_i+1*( u_i+1 - +u_i ) / ( x_i+1 - x_i )^2 - a_i*( u_i - u_i-1 ) / ( ( x_i+1 - x_i)*( x_i - x_i-1 ) ) In the case of non-spatially varying conductivity and constant grid spacing, this reduces the second-order, central difference formula for second derivative. |
Geothermal Reservoir 2D heat flow modelling | phobo | ANSYS | 0 | May 25, 2014 11:10 |
Transient Thermal: nonlinear heat equation | vagantes | ANSYS | 0 | May 2, 2013 06:38 |
Conjugate heat transfer, thermal boundary conditions | Sarah | Main CFD Forum | 1 | April 7, 2010 08:20 |
thermal diffusivity and specfic heat of NO2 | intern | CFX | 0 | May 6, 2002 12:07 |
Hot rod in transverse air flow | Anders Larsson | Main CFD Forum | 3 | April 19, 1999 10:28 |
