UDF for Vapor Adsorption in the Solution Diffusion Model |
August 4, 2014, 11:35 |
Hello All,
I am trying to model vapor transfer through a membrane. This process is described by the solution-diffusion model. The first step is modelling the adsorption of water vapor to the membrane. I am trying to implement adsorption isotherms using a UDF to do this. Does anyone have or know of a UDF that could be adapted to this problem? I do not know where to begin for such a UDF. Thanks, Tomas |
adsorption, mass transfer, membrane, udf |
UDF for turbulence model implementation | marluc | FLUENT | 1 | July 10, 2017 19:12 |
UDF for turbulence model | marluc | Fluent UDF and Scheme Programming | 0 | April 11, 2014 17:15 |
I want to Change Values in Existing UDF to Match my Model | mamkol | Fluent UDF and Scheme Programming | 1 | April 26, 2013 03:57 |
UDF error : DEFINE_PROPERTY with PDF Model | Abhilash Chandy | FLUENT | 0 | June 2, 2006 18:07 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 02:16 |
