Home > Forums > Software User Forums > SU2
Is there a Way to Specify Volumetric Heat Generation q\dot_gen in SU2?
Old   Yesterday, 20:56
Default Is there a Way to Specify Volumetric Heat Generation q\dot_gen in SU2?
PA
gkhokhar is on a distinguished road
I'm trying to run a case where I'm modeling combustion in a RAMJET.
There are options for wall heat flux, but I'd also like to use heat generation per unit volume.
This term is often included in the differential form of the energy equation, does SU2 allow a method for specifying this term?
Any help is appreciated.
gkhokhar is offline   Reply With Quote
Old   Today, 03:43
bigfoot
bigfootedrockmidget is on a distinguished road
We do not have exactly what you are asking for, although addition of general source terms has many applications.
Something like this has been implemented for the radiation model in incompressible flow. There is the config option HEAT_SOURCE, as part of the radiation model:
% Apply a volumetric heat source as a source term (NO, YES) in the form of an ellipsoid (YES, NO)
HEAT_SOURCE = NO
% Value of the volumetric heat source
HEAT_SOURCE_VAL = 1.0E6
% Rotation of the volumetric heat source respect to Z axis (degrees)
HEAT_SOURCE_ROTATION_Z = 0.0
% Position of heat source center (Heat_Source_Center_X, Heat_Source_Center_Y, Heat_Source_Center_Z)
HEAT_SOURCE_CENTER = ( 0.0, 0.0, 0.0 )
% Vector of heat source radii (Heat_Source_Radius_A, Heat_Source_Radius_B, Heat_Source_Radius_C)
HEAT_SOURCE_AXES = ( 1.0, 1.0, 1.0 )
But if you would like to use something like this in general to create a heat source for the energy equation, you need to add it to the compressible solver as well, and make its implementation independent of the radiation solver.
This method is also available through the python wrapper, if you would like to have many different heat sources available, it is probably best to implement it through the python wrapper.
bigfootedrockmidget is offline   Reply With Quote
Old   Today, 03:45
bigfoot
You could also use the NEMO solver for it, then you have detailed chemistry available in the compressible solver, but you can not separate the energy source from the chemistry. So it will be much more expensive.
Fluent battery heat generation fitting Zcfd FLUENT 1 October 22, 2024 03:28
Unsteady problem with volumetric heat source Jonathan94 STAR-CCM+ 1 July 21, 2018 03:26
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
How to Define heat generation rate that changes with the system coordinate. a19910112a OpenFOAM Running, Solving & CFD 2 December 12, 2014 04:22
Heat Generation rate in W/m³ ashghan OpenFOAM Programming & Development 0 June 27, 2014 06:42
