Home > Forums > Software User Forums > SU2
mesh quality metrics
Old   October 31, 2024, 09:21
Default mesh quality metrics
Giovanni Bettega
gbettega is on a distinguished road
Hello forum,
Computing mesh quality statistics for the dual control volumes.
| Mesh Quality Metric| Minimum| Maximum|
| Orthogonality Angle (deg.)| 2.72453| 53.1852|
| CV Face Area Aspect Ratio| 1.94744| 950.364|
| CV Sub-Volume Ratio| 1.22567| inf|
What about this? (the tetrahedral mesh generated by Tetgen)
Regards
Giovanni
gbettega is offline   Reply With Quote
Old   October 31, 2024, 16:10
bigfoot
bigfootedrockmidget is on a distinguished road
Maybe there is a cell of volume zero, causing a Sub-Volume ratio of infinity.
bigfootedrockmidget is offline   Reply With Quote
Old   October 31, 2024, 17:42
Giovanni Bettega
Thank you for your reply. I will check.
In case, is it "normal" that Su2 is able to start and diverges after some tens of steps (a steady state run)?
Is this Su2 message (I mean "Inf") coming from the dual grid? This last question is motivated by the fact that Teigen is very robust (never found a zero volume tetrahedron), and quality constraints are used for generating the grid
I'll check
Grazie!
Giovanni
Old   October 31, 2024, 18:37
Giovanni Bettega
The Tetgen mesh seems to be ok: no negative volume element.
This has also been checked within the application, with few additional lines scanning all the tetrahedra and compare each volume with std::numeric_limits<double>::epsilon: no zero volume elements are found.
Su2 starts, issues "inf", performs more than 200 inner iterations (CFL = 1.0) and stops because of divergence.
In attachment a short summary (pdf)
Giovanni
mesh, mesh quality criteria
[snappyHexMesh] snappyHexMesh stuck when snap is turned on yukuns OpenFOAM Meshing & Mesh Conversion 3 February 2, 2021 14:05
[snappyHexMesh] very bad quality snapped mesh federicabi OpenFOAM Meshing & Mesh Conversion 18 September 26, 2018 11:33
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
