Velocity magnitute ignored at inlet for incompressible flows |
October 30, 2024, 02:38 |
Tom-Robin Teschner
Rep Power: 16 |
I'm test driving SU2 at the moment to evaluate if I can use it for a few projects that I have lined up (after many years of frustration with OpenFOAM) and thus far I am rather pleased with SU2. The schemes and algorithms that are implemented are working rather well, not something I a used to from OpenFOAM (let's not go there ...).
The compressible setup seems straight forward and I can achieve what I want. I also wanted to evaluate the incompressible solver characteristics, and thus set up a simple NACA 0012 example for the classical NASA validation test case at Re=6E6 and Ma=0.15. I get good results for that with the RANS solver, but for INC_RANS, I seem to always get a magnitude of 1 at the velocity inlet, despite specifying a velocity inlet boundary condition with a non-zero value. I have tried now a few things, and probably I am just missing something here (I have also checked my setup against the available tutorial case), but my velocity vector always has a magnitude of 1 at the inlet. Here is my input: Code:
% ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% SOLVER= INC_RANS % Specify turbulence model (NONE, SA, SST) KIND_TURB_MODEL= SST % MATH_PROBLEM= DIRECT % % Restart solution (NO, YES) RESTART_SOL= NO % SYSTEM_MEASUREMENTS= SI % % ------------------------------- SOLVER CONTROL ------------------------------% % % Number of iterations for single-zone problems ITER= 1 % % Maximum number of inner iterations INNER_ITER= 500 % % Convergence field CONV_FIELD= DRAG % % Min value of the residual (log10 of the residual) CONV_RESIDUAL_MINVAL= -8 % % Number of elements to apply the criteria CONV_CAUCHY_ELEMS= 40 % % Epsilon to control the series convergence CONV_CAUCHY_EPS= 1E-4 % % ---------------- INCOMPRESSIBLE FLOW CONDITION DEFINITION -------------------% % % Density model within the incompressible flow solver. % Options are CONSTANT (default), BOUSSINESQ, VARIABLE, or FLAMELET. If VARIABLE, % an appropriate fluid model must be selected. For FLAMELET, the density is % retrieved directly from the flamelet manifold. INC_DENSITY_MODEL= CONSTANT % % Solve the energy equation in the incompressible flow solver INC_ENERGY_EQUATION = NO % % Initial density for incompressible flows % (1.2886 kg/m^3 by default (air), 998.2 Kg/m^3 (water)) INC_DENSITY_INIT= 1.2886 % % Initial velocity for incompressible flows (1.0,0,0 m/s by default) INC_VELOCITY_INIT= ( 84.96890112 , 14.98230979 , 0.00 ) % % Non-dimensionalization scheme for incompressible flows. Options are % INITIAL_VALUES (default), REFERENCE_VALUES, or DIMENSIONAL. % INC_*_REF values are ignored unless REFERENCE_VALUES is chosen. INC_NONDIM= INITIAL_VALUES % % List of inlet types for incompressible flows. List length must % match number of inlet markers. Options: VELOCITY_INLET, PRESSURE_INLET. INC_INLET_TYPE= VELOCITY_INLET % % List of outlet types for incompressible flows. List length must % match number of outlet markers. Options: PRESSURE_OUTLET, MASS_FLOW_OUTLET INC_OUTLET_TYPE= PRESSURE_OUTLET % % ---------------------- REFERENCE VALUE DEFINITION ---------------------------% % % Reference origin for moment computation (m or in) REF_ORIGIN_MOMENT_X = 0.25 REF_ORIGIN_MOMENT_Y = 0.00 REF_ORIGIN_MOMENT_Z = 0.00 % % Reference length for moment non-dimensional coefficients (m or in) REF_LENGTH= 1.0 % % Reference velocity (incompressible only) REF_VELOCITY= 8.63E1 % % Reference viscosity (incompressible only) REF_VISCOSITY= 1.853E-5 % % Reference area for non-dimensional force coefficients (0 implies automatic % calculation) (m^2 or in^2) REF_AREA= 1.0 % % --------------------------- VISCOSITY MODEL ---------------------------------% % % Viscosity model (SUTHERLAND, CONSTANT_VISCOSITY, POLYNOMIAL_VISCOSITY, FLAMELET). VISCOSITY_MODEL= CONSTANT_VISCOSITY % % Molecular Viscosity that would be constant (1.716E-5 by default) MU_CONSTANT= 1.853E-5 % % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % % Navier-Stokes (no-slip), isothermal wall marker(s) (NONE = no marker) % Format: ( marker name, constant wall temperature (K), ... ) MARKER_ISOTHERMAL= ( upper, 288.15, lower, 288.15, te, 288.15 ) % % Inlet boundary type (TOTAL_CONDITIONS, MASS_FLOW) INLET_TYPE= TOTAL_CONDITIONS % % Inlet boundary marker(s) with the following formats (NONE = no marker) % Total Conditions: (inlet marker, total temp, total pressure, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. % Mass Flow: (inlet marker, density, velocity magnitude, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. % Inc. Velocity: (inlet marker, temperature, velocity magnitude, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. % Inc. Pressure: (inlet marker, temperature, total pressure, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. MARKER_INLET= ( inlet, 0.0, 86.28, 0.984807753, 0.173648178, 0.0 ) MARKER_INLET_TURBULENT= ( inlet, 0.00052, 10.0 ) % % Outlet boundary marker(s) (NONE = no marker) % Compressible: ( outlet marker, back pressure (static thermodynamic), ... ) % Inc. Pressure: ( outlet marker, back pressure (static gauge in Pa), ... ) % Inc. Mass Flow: ( outlet marker, mass flow target (kg/s), ... ) MARKER_OUTLET= ( outlet, 0.0 ) % % ------------------------ SURFACES IDENTIFICATION ----------------------------% % % Marker(s) of the surface in the surface flow solution file MARKER_PLOTTING = ( upper, lower, te ) % % Marker(s) of the surface where the non-dimensional coefficients are evaluated. MARKER_MONITORING = ( upper, lower, te ) % % Viscous wall markers for which wall functions must be applied. (NONE = no marker) % Format: ( marker name, wall function type -NO_WALL_FUNCTION, STANDARD_WALL_FUNCTION, % ADAPTIVE_WALL_FUNCTION, SCALABLE_WALL_FUNCTION, EQUILIBRIUM_WALL_MODEL, % NONEQUILIBRIUM_WALL_MODEL-, ... ) MARKER_WALL_FUNCTIONS= ( upper, NO_WALL_FUNCTION, lower, NO_WALL_FUNCTION, te, NO_WALL_FUNCTION ) % % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % % Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES) NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES % % Numerical method for spatial gradients to be used for MUSCL reconstruction % Options are (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES, LEAST_SQUARES). Default value is % NONE and the method specified in NUM_METHOD_GRAD is used. NUM_METHOD_GRAD_RECON = WEIGHTED_LEAST_SQUARES % % CFL number (initial value for the adaptive CFL number) CFL_NUMBER= 10.0 % % Adaptive CFL number (NO, YES) CFL_ADAPT= YES % % Parameters of the adaptive CFL number (factor-down, factor-up, CFL min value, % CFL max value, acceptable linear solver convergence) % Local CFL increases by factor-up until max if the solution rate of change is not limited, % and acceptable linear convergence is achieved. It is reduced if rate is limited, or if there % is not enough linear convergence, or if the nonlinear residuals are stagnant and oscillatory. % It is reset back to min when linear solvers diverge, or if nonlinear residuals increase too much. CFL_ADAPT_PARAM= ( 0.1, 2.0, 10.0, 1e10, 0.1 ) % % Maximum Delta Time in local time stepping simulations MAX_DELTA_TIME= 1E6 % % External iteration offset due to restart EXT_ITER_OFFSET= 0 % % Runge-Kutta alpha coefficients RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 ) % % ----------- SLOPE LIMITER AND DISSIPATION SENSOR DEFINITION -----------------% % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the flow equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_FLOW= NO % % Slope limiter (NONE, VENKATAKRISHNAN, VENKATAKRISHNAN_WANG, BARTH_JESPERSEN, VAN_ALBADA_EDGE, % NISHIKAWA_R3, NISHIKAWA_R4, NISHIKAWA_R5) SLOPE_LIMITER_FLOW= VENKATAKRISHNAN % % Same as MUSCL_FLOW but for turbulence. % MUSCL_TURB= NO % % Slope limiter (same as SLOPE_LIMITER_FLOW except VAN_ALBADA_EDGE) % SLOPE_LIMITER_TURB= VENKATAKRISHNAN % % Same as MUSCL_FLOW but for the continuous adjoint equations. % MUSCL_ADJFLOW= YES % % Slope limiter (same as SLOPE_LIMITER_FLOW plus SHARP_EDGES, WALL_DISTANCE) % SLOPE_LIMITER_ADJFLOW= VENKATAKRISHNAN % % Same as MUSCL_FLOW but for continuous adjoint turbulence equations. % MUSCL_ADJTURB= NO % % Slope limiter (see SLOPE_LIMITER_ADJFLOW) % SLOPE_LIMITER_ADJTURB= VENKATAKRISHNAN % % Coefficient for Venkatakrishnan-type limiters (upwind scheme). % A larger value decreases the extent of limiting, values approaching zero % cause lower-order approximation to the solution (0.05 by default) VENKAT_LIMITER_COEFF= 0.05 % % Reference coefficient for detecting sharp edges (3.0 by default). REF_SHARP_EDGES = 3.0 % % Coefficient for the adjoint sharp edges limiter (3.0 by default). ADJ_SHARP_LIMITER_COEFF= 3.0 % % Remove sharp edges from the sensitivity evaluation (NO, YES) SENS_REMOVE_SHARP = NO % SENS_SMOOTHING= NONE % % Freeze the value of the limiter after a number of iterations LIMITER_ITER= 999999 % % 1st order artificial dissipation coefficients for % the Lax–Friedrichs method ( 0.15 by default ) LAX_SENSOR_COEFF= 0.15 % % 2nd and 4th order artificial dissipation coefficients for % the JST method ( 0.5, 0.02 by default ) JST_SENSOR_COEFF= ( 0.5, 0.02 ) % % 1st order artificial dissipation coefficients for % the adjoint Lax–Friedrichs method ( 0.15 by default ) ADJ_LAX_SENSOR_COEFF= 0.15 % % 2nd, and 4th order artificial dissipation coefficients for % the adjoint JST method ( 0.5, 0.02 by default ) ADJ_JST_SENSOR_COEFF= ( 0.5, 0.02 ) % % ------------------------ LINEAR SOLVER DEFINITION ---------------------------% % % Linear solver or smoother for implicit formulations: % BCGSTAB, FGMRES, RESTARTED_FGMRES, CONJUGATE_GRADIENT (self-adjoint problems only), SMOOTHER. LINEAR_SOLVER= FGMRES % % Preconditioner of the Krylov linear solver or type of smoother (ILU, LU_SGS, LINELET, JACOBI) LINEAR_SOLVER_PREC= LU_SGS % % Linear solver ILU preconditioner fill-in level (0 by default) LINEAR_SOLVER_ILU_FILL_IN= 0 % % Minimum error of the linear solver for implicit formulations LINEAR_SOLVER_ERROR= 1E-10 % % Max number of iterations of the linear solver for the implicit formulation LINEAR_SOLVER_ITER= 10 % % Restart frequency for RESTARTED_FGMRES LINEAR_SOLVER_RESTART_FREQUENCY= 10 % % Relaxation factor for smoother-type solvers (LINEAR_SOLVER= SMOOTHER) LINEAR_SOLVER_SMOOTHER_RELAXATION= 1.0 % % -------------------------- MULTIGRID PARAMETERS -----------------------------% % % Multi-grid levels (0 = no multi-grid) MGLEVEL= 4 % % Multi-grid cycle (V_CYCLE, W_CYCLE, FULLMG_CYCLE) MGCYCLE= V_CYCLE % % Multi-grid pre-smoothing level MG_PRE_SMOOTH= ( 5, 5, 5, 5, 5 ) % % Multi-grid post-smoothing level MG_POST_SMOOTH= ( 5, 5, 5, 5, 5 ) % % Jacobi implicit smoothing of the correction MG_CORRECTION_SMOOTH= ( 5, 5, 5, 5, 5 ) % % Damping factor for the residual restriction MG_DAMP_RESTRICTION= 0.5 % % Damping factor for the correction prolongation MG_DAMP_PROLONGATION= 0.5 % % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % % Convective numerical method (JST, JST_KE, JST_MAT, LAX-FRIEDRICH, ROE, AUSM, % AUSMPLUSUP, AUSMPLUSUP2, AUSMPLUSM, HLLC, TURKEL_PREC, % SW, MSW, FDS, SLAU, SLAU2, L2ROE, LMROE) CONV_NUM_METHOD_FLOW= LAX-FRIEDRICH % % Roe Low Dissipation function for Hybrid RANS/LES simulations (FD, NTS, NTS_DUCROS) ROE_LOW_DISSIPATION= FD % % Roe dissipation coefficient ROE_KAPPA= 0.5 % % Minimum value for beta for the Roe-Turkel preconditioner MIN_ROE_TURKEL_PREC= 0.01 % % Maximum value for beta for the Roe-Turkel preconditioner MAX_ROE_TURKEL_PREC= 0.2 % % Post-reconstruction correction for low Mach number flows (NO, YES) LOW_MACH_CORR= NO % % Roe-Turkel preconditioning for low Mach number flows (NO, YES) LOW_MACH_PREC= NO % % Use numerically computed Jacobians for AUSM+up(2) and SLAU(2) % Slower per iteration but potentialy more stable and capable of higher CFL USE_ACCURATE_FLUX_JACOBIANS= NO % % Use the vectorized version of the selected numerical method (available for JST family and Roe). % SU2 should be compiled for an AVX or AVX512 architecture for best performance. % NOTE: Currently vectorization always used for schemes that support it. USE_VECTORIZATION= YES % % Entropy fix coefficient (0.0 implies no entropy fixing, 1.0 implies scalar % artificial dissipation) ENTROPY_FIX_COEFF= 0.5 % % Higher values than 1 (3 to 4) make the global Jacobian of central schemes (compressible flow % only) more diagonal dominant (but mathematically incorrect) so that higher CFL can be used. CENTRAL_JACOBIAN_FIX_FACTOR= 4.0 % % Control numerical properties of the global Jacobian matrix using a multiplication factor % for incompressible central schemes CENTRAL_INC_JACOBIAN_FIX_FACTOR= 1.0 % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT) TIME_DISCRE_FLOW= EULER_IMPLICIT % % Use a Newton-Krylov method on the flow equations, see TestCases/rans/oneram6/turb_ONERAM6_nk.cfg % For multizone discrete adjoint it will use FGMRES on inner iterations with restart frequency % equal to "QUASI_NEWTON_NUM_SAMPLES". NEWTON_KRYLOV= NO % % Integer parameters {startup iters, precond iters, initial tolerance relaxation}. NEWTON_KRYLOV_IPARAM= (10, 3, 2) % % Double parameters {startup residual drop, precond tolerance, full tolerance residual drop, findiff step}. NEWTON_KRYLOV_DPARAM= (1.0, 0.1, -6.0, 1e-5) % % ------------------- FEM FLOW NUMERICAL METHOD DEFINITION --------------------% % % FEM numerical method (DG) NUM_METHOD_FEM_FLOW= DG % % Riemann solver used for DG (ROE, LAX-FRIEDRICH, AUSM, HLLC, VAN_LEER) RIEMANN_SOLVER_FEM= HLLC % % Constant factor applied for quadrature with straight elements (2.0 by default) QUADRATURE_FACTOR_STRAIGHT_FEM = 2.0 % % Constant factor applied for quadrature with curved elements (3.0 by default) QUADRATURE_FACTOR_CURVED_FEM = 3.0 % % Factor for the symmetrizing terms in the DG FEM discretization (1.0 by default) THETA_INTERIOR_PENALTY_DG_FEM = 1.0 % % Compute the entropy in the fluid model (YES, NO) COMPUTE_ENTROPY_FLUID_MODEL= YES % % Use the lumped mass matrix for steady DGFEM computations (NO, YES) USE_LUMPED_MASSMATRIX_DGFEM= NO % % Only compute the exact Jacobian of the spatial discretization (NO, YES) JACOBIAN_SPATIAL_DISCRETIZATION_ONLY= NO % % Number of aligned bytes for the matrix multiplications. Multiple of 64. (128 by default) ALIGNED_BYTES_MATMUL= 128 % % Time discretization (RUNGE-KUTTA_EXPLICIT, CLASSICAL_RK4_EXPLICIT, ADER_DG) TIME_DISCRE_FEM_FLOW= RUNGE-KUTTA_EXPLICIT % % Number of time DOFs for the predictor step of ADER-DG (2 by default) TIME_DOFS_ADER_DG= 2 % Factor applied during quadrature in time for ADER-DG. (2.0 by default) %QUADRATURE_FACTOR_TIME_ADER_DG = 2.0 % % Type of discretization used in the predictor step of ADER-DG (ADER_ALIASED_PREDICTOR, ADER_NON_ALIASED_PREDICTOR) ADER_PREDICTOR= ADER_ALIASED_PREDICTOR % Number of time levels for time accurate local time stepping. (1 by default, max. allowed 15) LEVELS_TIME_ACCURATE_LTS= 1 % % Specify the method for matrix coloring for Jacobian computations (GREEDY_COLORING, NATURAL_COLORING) KIND_MATRIX_COLORING= GREEDY_COLORING % % Specify shock capturing method for DG KIND_FEM_DG_SHOCK= NONE % % ------------------------- SCREEN/HISTORY VOLUME OUTPUT --------------------------% % % Screen output fields (use 'SU2_CFD -d <config_file>' to view list of available fields) SCREEN_OUTPUT= (INNER_ITER, RMS_PRESSURE, DRAG, LIFT, MIN_CFL, AVG_CFL, MAX_CFL, MAX_VELOCITY-X) % % History output groups (use 'SU2_CFD -d <config_file>' to view list of available fields) HISTORY_OUTPUT= (ITER, RMS_PRESSURE, RMS_MOMENTUM-X, RMS_MOMENTUM-Y, DRAG, LIFT) % % Volume output fields/groups (use 'SU2_CFD -d <config_file>' to view list of available fields) VOLUME_OUTPUT= (COORDINATES, SOLUTION, PRIMITIVE) % % Writing frequency for screen output SCREEN_WRT_FREQ_INNER= 10 % SCREEN_WRT_FREQ_OUTER= 1 % SCREEN_WRT_FREQ_TIME= 1 % % Writing frequency for history output HISTORY_WRT_FREQ_INNER= 1 % HISTORY_WRT_FREQ_OUTER= 1 % HISTORY_WRT_FREQ_TIME= 1 % % list of writing frequencies corresponding to the list in OUTPUT_FILES OUTPUT_WRT_FREQ= 250, 250, 250 % % Output the performance summary to the console at the end of SU2_CFD WRT_PERFORMANCE= YES % % Output the tape statistics (discrete adjoint) WRT_AD_STATISTICS= NO % % % Overwrite or append iteration number to the restart files when saving WRT_RESTART_OVERWRITE= YES % % Overwrite or append iteration number to the surface files when saving WRT_SURFACE_OVERWRITE= YES % % Overwrite or append iteration number to the volume files when saving WRT_VOLUME_OVERWRITE= YES % % Determines if the forces breakdown is written out WRT_FORCES_BREAKDOWN= NO % % MPI communication level (NONE, MINIMAL, FULL) COMM_LEVEL= FULL % % Node number for the CV to be visualized (tecplot) (delete?) VISUALIZE_CV= -1 % % Write extra output (EXPERIMENTAL, NOT FOR GENERAL USE) EXTRA_OUTPUT= NO % % Write extra heat output for a given heat solver zone EXTRA_HEAT_ZONE_OUTPUT= -1 % % ------------------------- INPUT/OUTPUT FILE INFORMATION --------------------------% % % Mesh input file MESH_FILENAME= naca_0012.su2 % % Mesh input file format (SU2, CGNS) MESH_FORMAT= SU2 % % Restart flow input file SOLUTION_FILENAME= restart_flow.dat % % Output tabular file format (TECPLOT, CSV) TABULAR_FORMAT= CSV % OUTPUT_PRECISION= 10 % % Files to output OUTPUT_FILES= (RESTART, PARAVIEW, SURFACE_PARAVIEW) % % Output file convergence history (w/o extension) CONV_FILENAME= history % % Output file with the forces breakdown BREAKDOWN_FILENAME= forces_breakdown.dat % % Output file restart flow RESTART_FILENAME= restart_flow.dat % % Output file flow (w/o extension) variables VOLUME_FILENAME= flow % % Output file surface flow coefficient (w/o extension) SURFACE_FILENAME= surface_flow % |
October 30, 2024, 03:09 |
bigfoot
Rep Power: 19 |
You are using nondimensionalization of the results:
% Non-dimensionalization scheme for incompressible flows. Options are % INITIAL_VALUES (default), REFERENCE_VALUES, or DIMENSIONAL. % INC_*_REF values are ignored unless REFERENCE_VALUES is chosen. INC_NONDIM= INITIAL_VALUES You can change your code to: Code:
INC_NONDIM=DIMENSIONAL We have some explanation here: https://su2code.github.io/docs_v7/Ph...incompressible |
October 30, 2024, 06:56 |
Tom-Robin Teschner
Rep Power: 16 |
I suspected as much, but for some reason, I missed that! Thanks for the help, it is much appreciated!
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
simpleFoam: Non-uniform mesh near inlet & outlet causes incorrect velocity profile? | Zaphod'sSecondHead | OpenFOAM Running, Solving & CFD | 0 | January 28, 2015 06:17 |
Inlet Velocity in CFX | aeroman | CFX | 12 | August 6, 2009 19:42 |
UDF problem : inlet velocity in cyl. coord. system | Jongdae Kim | FLUENT | 0 | June 15, 2004 12:21 |
length scales at inlet for internal flows | Anne-Marie Giroux | Main CFD Forum | 3 | July 5, 1999 22:28 |
