Problem with running SU2 with Euler solver on Windows |
October 30, 2024, 00:00 |
Avijeet
Rep Power: 14 |
Hi All,
I'm facing a problem in running SU2 with Euler solver on Windows. Every thing is fine if I I'm using the RANS solver. But when i use the Euler solver, i keep getting the following error whenever SU2 is trying to write out the output files (Surface, Volume, Restart): Error in "void COutput::SetVolumeOutputValue(const string&, long unsigned int, su2double)" Cannot find output field with name SKIN_FRICTION-X Don't understand why SU2 is trying to write out Skin friction when Euler solver is selected. I have tried specifying the things I want in VOLUME_OUTPUT. i tried all different format options for Surface, Volume and Restart files and even tried skipping Restart files. But nothing seems to resolve the issue. Versions tried: SU2-v8.0.0-win64 and SU2-v8.1.0-win64-mpi. TIA. |
October 30, 2024, 02:51 |
bigfoot
Rep Power: 21 |
Do you have a test case that reproduces this issue?
October 30, 2024, 08:04 |
Avijeet
Rep Power: 14 |
Please see the attached files
Also, there is another error on Windows, even with RANS solver. just comment out line 231 and uncomment line 232 after changing solver to RANS, so that the volume and surface output files are Tecplot Binary. There is an error related to tecZoneNodeMapWrite64 which doesn't happen for paraview format. |
October 30, 2024, 10:10 |
Rutvik Khedkar
Rep Power: 2 |
I encountered this before as well. You need to set the wall boundary condition as MARKER_EULER. MARKER_ISOTHERMAL, _HEATFLUX and _HEATTRANSFER boundary conditions are for viscous simulations, so they work fine for RANS or NS solvers.
October 30, 2024, 10:16 |
bigfoot
Rep Power: 21 |
Thanks, R.K. , I remembered that there was an issue about this before but not what it was about. I think the long-term solution is to give an error message when the user wants to use viscous boundaries for a non-viscous solver.
November 4, 2024, 03:26 |
Avijeet
Rep Power: 14 |
November 4, 2024, 03:27 |
Avijeet
Rep Power: 14 |
Please look into the Tecplot format issues if possible.
November 4, 2024, 15:43 |
Rutvik Khedkar
Rep Power: 2 |
can you upload the files so i can recreate the error? Have you installed SU2 directly on windows or through a linux virtual box on windows?
it may be a compiler issue: https://bugzilla.redhat.com/show_bug.cgi?id=1879254 |
November 5, 2024, 00:47 |
#9 | ||
Avijeet
Rep Power: 14 |
November 5, 2024, 06:23 |
#10 |
Rutvik Khedkar
Rep Power: 2 |
i think you deleted the files. i cant see them.
November 5, 2024, 11:12 |
#12 |
Rutvik Khedkar
Rep Power: 2 |
I ran your case on version 8.0.1 and 8.1.0 (with all of the tecplot files as the output files) it worked fine, giving the tecplot output files. Can you post the verbatim of the error?
When you run any tutorial/testcase with an output for Tecplot, do you get the same error? Did you follow the guide when installing? https://su2code.github.io/docs_v7/Build-SU2-Windows/ can you try running SU2 through WSL? |
bug, error, euler, restart, su2 |
problem regarding solver running two times | Vishal Garg | OpenFOAM Running, Solving & CFD | 1 | October 19, 2023 04:22 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 07:33 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
SU2 running problem | andrea.ciarella | SU2 | 5 | May 16, 2013 16:02 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 06:03 |
