October 24, 2024, 09:50 |
SU2 Turbulent Flat Plate
Rep Power: 2 |
Hello guys, https://su2code.github.io/tutorials/...nt_Flat_Plate/
in this tutorial, the flat plate length is "2m" as stated. However, in su2 code % Reynolds length (in meters) REYNOLDS_LENGTH= 1.0 % Reference length for pitching, rolling, and yawing non-dimensional moment REF_LENGTH= 1.0 % % Reference area for force coefficients (0 implies automatic calculation) REF_AREA= 2.0 So, in the calculation of Reynolds number, the length is based on 1m or 2m??? And why did not they use 2.0 for Reynolds_Length and Ref_Area? I did not understand this part... Last edited by dxdiag; October 24, 2024 at 09:51. Reason: web site |
October 24, 2024, 11:14 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
"% Reynolds length (in meters)" what is that, a dimensional number? I see the figure showing the velocity profile in a turbulent BL. That means you have a fully developed turbulent flow along a flat plate, corresponding to a local Reynolds number of about 10^6. On a flat plate there is only a local Re_x value. The Re_tau is a different parameter. |
October 26, 2024, 17:26 |
Rep Power: 2 |
I don't know exactly because I'm trying to learn. Why is the area 2 when the Reynolds Length and Ref Length values are 1?
cfd, flat plate, flow simulation, su2 |
Nonequilibrium Turbulent Boundary Layers on Flat Plate Analysis | erenbkaya | OpenFOAM Running, Solving & CFD | 0 | April 25, 2023 09:42 |
Drag Force Ratio for Flat Plate | Rob Wilk | Main CFD Forum | 40 | May 10, 2020 05:47 |
k-omega-SST model (OF 1.6) - turbulent flat plate | cboss | OpenFOAM Running, Solving & CFD | 25 | August 9, 2016 10:53 |
RhoSimpleFoam - turbulent flow over a flat plate | Delcraft | OpenFOAM Verification & Validation | 1 | November 29, 2014 08:07 |
Turbulent Boundary Layer on a Flat Plate | Hoshang Garda | FLUENT | 1 | November 27, 2013 11:24 |
