Home > Forums > Software User Forums > SU2
compute time-averaged solution
Old   October 6, 2024, 10:44
Default compute time-averaged solution
hewei is on a distinguished road
I am studying an airfoil separated flow case using SU2, I run the tutorial case and have the unsteady solution in time. I am trying to solve the time averaged solution, e.g. in 3 periods, and output the mean flow fields, as well as the mean coefficients on the surface. I have activate the option
% Compute the average solution for unsteady simulations (NO, YES)
COMPUTE_AVERAGE= YES
% Restart the average process from a previous averaged solution (NO, YES)
%RESTART_AVERAGE= NO
%% Starting iteration and type for windowed-time-averaging
WINDOW_CAUCHY_CRIT= YES
WINDOW_START_ITER= 1200
WINDOW_FUNCTION= HANN_SQUARE
When I check the solution, there is no averaged solution neither in the field nor on surface data. could you please help me how to set the configure file?
Thank you!
hewei
hewei is offline   Reply With Quote
Old   October 6, 2024, 16:21
bigfoot
bigfootedrockmidget is on a distinguished road
you can add the keyword TIME_AVERAGE to the volume output.
Alternatively, you can add all available time averaged quantities, like MEAN_DENSITY, MEAN_VELOCITY-X, RMS_U, ...
bigfootedrockmidget is offline   Reply With Quote
Old   October 6, 2024, 22:15
It works, thank you very much!
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
LES, Courant Number, Crash, Sudden Alhasan OpenFOAM Running, Solving & CFD 5 November 22, 2019 03:05
time averaged solution in post processing coolwave Fidelity CFD 0 September 4, 2015 09:29
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
