October 4, 2024, 05:56 |
Save or extract the Cp on the multi surfaces
Rep Power: 16 |
Dear all,
Currently I am learning SU2 and aiming to solve an airfoil compressible flow. I defined the surface parts separately as Airfoil_LS, Airfoil_US, in order to plot the Cp along the chord Here are the definition of the boundary conditions MARKER_HEATFLUX= ( Airfoil_US, 0.0, Airfoil_LS, 0.0, Airfoil_TS, 0.0 ) MARKER_FAR= ( Farfield ) MARKER_PLOTTING= ( Airfoil_US, Airfoil_LS, Airfoil_TS ) MARKER_MONITORING= ( Airfoil_US, Airfoil_LS, Airfoil_TS ) In Tecplot, the Cp can be visualized correctly, but the Cp on two surfaces is saved in one file and I cannot split the upper and lower surfaces, because the airfoil is cambered. Is there a way to separate the data for upper and lower surface, or extract the Cp on each Marker? Thank you! Wei |
October 6, 2024, 16:24 |
bigfoot
Rep Power: 21 |
I do not know anything about tecplot, but for paraview, you can save it in PARAVIEW_MULTIBLOCK format, which has all surface available as separate blocks.
October 7, 2024, 03:51 |
Rep Power: 16 |
Combine part surfaces if along a specified plane | miragemobile | STAR-CCM+ | 1 | March 26, 2019 19:43 |
how to get two sided surfaces | sebbel | CFX | 1 | November 16, 2018 03:45 |
Cannot extract surfaces of the .vtk file in Paraview | cfdcar | SU2 | 4 | August 15, 2018 10:46 |
Out of memory while sampling surfaces | xuegy | OpenFOAM Running, Solving & CFD | 2 | November 3, 2016 12:03 |
Extract surfaces? | HP | FLUENT | 3 | August 15, 2005 11:16 |
