Home > Forums > Software User Forums > SU2
Tumbling Cylinder simulation
Old   September 28, 2024, 11:49
Post Tumbling Cylinder simulation
Athos_e is on a distinguished road
Hello everyone,
I am trying to simulate a tumbling cylinder re-entering the atmosphere. I wanted to see if there is a way in SU2 to get the rotation of the cylinder based on the aerodynamic forces acting on it. I have played around using moving grid and set some rotation around each axis and this works fine. However it is not realistic as the rotation of the cylinder is dependent on the aerodynamics forces. Translational motion can be ignored for the moment, I am only curious on the rotational movement. At the end I will want to calculate the overall Drag on the body.
As a second question I wanted to just make sure that NEMO solver is still not compatible with moving grids. I have tried it in another case in the past and the simulation wouldn't start. So I just wanted to make sure that this is the reason and I am not missing something else.
Thanks a lot for the help!
Athos_e is offline   Reply With Quote
moving 3d mesh, moving grid, re-entry, su2
Simulation of flow around a cylinder in OpenFOAM martinmat13 OpenFOAM 2 November 17, 2023 08:24
[blockMesh] Trouble building blockMeshDict for cylinder in Karman vortex simulation jdnesbitt OpenFOAM Meshing & Mesh Conversion 2 November 2, 2023 13:09
LES - simulation over cylinder. gu1 OpenFOAM Running, Solving & CFD 0 May 8, 2017 10:34
Running a feedback control simulation of the flow around a cylinder gasagna OpenFOAM Running, Solving & CFD 0 July 16, 2014 11:03
modification for rotating cylinder simulation zonexo Main CFD Forum 3 July 21, 2006 15:24
