Home > Forums > Software User Forums > SU2
History Output file: Turbulent Kinetic Energy
Old   September 27, 2024, 06:18
Default History Output file: Turbulent Kinetic Energy
Federico Vegetti
Federico Vegetti is on a distinguished road
I was wondering if there's any options for history output to include the turbulent kinetic energy.
I'm running an URANS, using the Equips module, and I've set as Options for history output TURB_KINETIC_ENERGY and TAVG_TKE but none of them works.
Anyone could help me, please?
Thanks in advance,
Federico
Federico Vegetti is offline   Reply With Quote
Old   September 27, 2024, 18:57
bigfoot
bigfootedrockmidget is on a distinguished road
When you do a dry run using SU2_CFD -d config.cfg, you will get all available screen/history outputs. You can also create additional outputs using CUSTOM_OUTPUTS
For instance to compute averages on the markers z_minus and z_plus, or to compute velocities in a point:
CUSTOM_OUTPUTS= 'velocity : Macro{sqrt(pow(VELOCITY_X, 2) + pow(VELOCITY_Y, 2) + pow(VELOCITY_Z, 2))};\
                 avg_vel : AreaAvg{$velocity}[z_minus, z_plus];\
                 var_vel : AreaAvg{pow($velocity - avg_vel, 2)}[z_minus, z_plus];\
                 dev_vel : Function{sqrt(var_vel) / avg_vel};\
                 probe1 : Probe{$velocity}[0.005, 0.005, 0.05]'
HISTORY_OUTPUT= ITER, RMS_RES, CUSTOM
You can use turbulent kinetic energy here as well using the keyword TURB[0] and TURB[1] for tke and dissipation.
bigfootedrockmidget is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
