September 26, 2024, 22:52 |
lobb case
李以乐
Rep Power: 2 |
hello everyone,
Recently, I have been working on a two-dimensional axisymmetric ball head case. The calculation conditions are: incoming Mach number of 15.3, velocity of 5280 m/s, temperature of 293 K, pressure of 664 Pa, Reynolds number of 14605, and isothermal wall conditions. The wall temperature is 1200 K, the ball head radius is 6.35 mm, and the characteristic length of Reynolds number is the head radius of the model. However, when I drew the grid and set up the configuration file, running su2 stopped shortly after. I guess my configuration file was the only problem, I hope to find a solution,thanks |
September 26, 2024, 23:03 |
李以乐
Rep Power: 2 |
What is the content of my configuration file is:
% ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% % SOLVER= NEMO_NAVIER_STOKES MATH_PROBLEM= DIRECT RESTART_SOL= NO AXISYMMETRIC= YES % ----------- COMPRESSIBLE AND INCOMPRESSIBLE FREE-STREAM DEFINITION ----------% % MACH_NUMBER=15.3 AOA= 0.0 SIDESLIP_ANGLE= 0.0 FREESTREAM_PRESSURE=664 FREESTREAM_TEMPERATURE=293 FREESTREAM_TEMPERATURE_VE=293 REYNOLDS_LENGTH= 0.00635 %FREESTREAM_DENSITY= 0.001547 FREESTREAM_VELOCITY= (5280.00, 0.00, 0.00 ) INIT_OPTION=TD_CONDITIONS % ---- NONEQUILIBRIUM GAS, IDEAL GAS, POLYTROPIC, VAN DER WAALS AND PENG ROBINSON CONSTANTS -------% % FLUID_MODEL= SU2_NONEQ GAS_MODEL= AIR-5 GAS_COMPOSITION= (0.77, 0.23, 0.0, 0.0, 0.0) TRANSPORT_COEFF_MODEL= GUPTA-YOS % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % MARKER_ISOTHERMAL=(wall, 1200.0) MARKER_FAR= (far, exit) MARKER_SYM= (symm) MARKER_PLOTTING= (wall) MARKER_MONITORING= (wall) %CATALYTIC_WALL= (wall) %SUPERCATALYTIC_WALL= YES %SUPERCATALYTIC_WALL_COMPOSITION= (0.75430935, 0.00713, 0.01026, 0.00000065, 0.2283) % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES CFL_NUMBER= 3.0 ITER= 1000000 LINEAR_SOLVER= BCGSTAB LINEAR_SOLVER_ERROR= 1E-6 LINEAR_SOLVER_ITER= 5 % -----------------------------------------------------------------------% % CONV_NUM_METHOD_FLOW= AUSM MUSCL_FLOW= YES SLOPE_LIMITER_FLOW= VENKATAKRISHNAN VENKAT_LIMITER_COEFF= 0.05 TIME_DISCRE_FLOW= EULER_IMPLICIT % --------------------------- CONVERGENCE PARAMETERS --------------------------% % CONV_RESIDUAL_MINVAL= -6 CONV_STARTITER= 10 % ------------------------- INPUT/OUTPUT INFORMATION --------------------------% % MESH_FILENAME= lobb.su2 MESH_FORMAT= SU2 SOLUTION_FILENAME= restart_flow_gy.dat RESTART_FILENAME= restart_flow_gy.dat TABULAR_FORMAT= TECPLOT CONV_FILENAME= convergence VOLUME_FILENAME= soln_volume SURFACE_FILENAME= soln_surface OUTPUT_WRT_FREQ= 2500 SCREEN_OUTPUT= (INNER_ITER, RMS_DENSITY_0, RMS_DENSITY_1, RMS_DENSITY_2, RMS_DENSITY_3, RMS_DENSITY_4, RMS_ENERGY, RMS_ENERGY_VE, LIFT, DRAG, TOTAL_HEATFLUX) |
September 27, 2024, 18:47 |
bigfoot
Rep Power: 21 |
why did SU2 stop? Did the solution diverge or was there another error?
September 27, 2024, 22:40 |
李以乐
Rep Power: 2 |
yeah,the solution diverge,after making some modifications to the configuration file, it can now run normally, but I don't understand how the boundary condition MARK OUT LET=(out, 100) is solved for 100,
This is my modified configuration file, with the main change being the boundary conditions section, %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % % % SU2 configuration file % %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% % SOLVER= NEMO_NAVIER_STOKES MATH_PROBLEM= DIRECT RESTART_SOL= NO AXISYMMETRIC= YES % ----------- COMPRESSIBLE AND INCOMPRESSIBLE FREE-STREAM DEFINITION ----------% % SYSTEM_MEASUREMENTS= SI MACH_NUMBER=15.3 AOA= 0.0 SIDESLIP_ANGLE= 0.0 FREESTREAM_PRESSURE=664 FREESTREAM_TEMPERATURE=293 FREESTREAM_TEMPERATURE_VE=293 INIT_OPTION=TD_CONDITIONS % ---- NONEQUILIBRIUM GAS, IDEAL GAS, POLYTROPIC, VAN DER WAALS AND PENG ROBINSON CONSTANTS -------% % FLUID_MODEL= SU2_NONEQ GAS_MODEL= AIR-5 GAS_COMPOSITION= (0.77, 0.23, 0.0, 0.0, 0.0) %TRANSPORT_COEFF_MODEL= GUPTA-YOS % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % MARKER_ISOTHERMAL=(wall, 1200.0) MARKER_FAR= (far) MARKER_OUTLET=(out,100) MARKER_SYM= (symm) MARKER_PLOTTING= (wall) MARKER_MONITORING= (wall) % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES CFL_NUMBER= 0.5 ITER= 1000000 LINEAR_SOLVER= BCGSTAB LINEAR_SOLVER_ERROR= 1E-6 LINEAR_SOLVER_ITER= 5 % -----------------------------------------------------------------------% % CONV_NUM_METHOD_FLOW= AUSM MUSCL_FLOW= YES SLOPE_LIMITER_FLOW= VENKATAKRISHNAN VENKAT_LIMITER_COEFF= 0.05 TIME_DISCRE_FLOW= EULER_IMPLICIT % --------------------------- CONVERGENCE PARAMETERS --------------------------% % CONV_RESIDUAL_MINVAL= -10 CONV_STARTITER= 10 % ------------------------- INPUT/OUTPUT INFORMATION --------------------------% % MESH_FILENAME= lobb.su2 MESH_FORMAT= SU2 SOLUTION_FILENAME= restart_flow_gy.dat RESTART_FILENAME= restart_flow_gy.dat TABULAR_FORMAT= TECPLOT CONV_FILENAME= convergence VOLUME_FILENAME= soln_volume SURFACE_FILENAME= soln_surface OUTPUT_WRT_FREQ= 2500 SCREEN_OUTPUT= (INNER_ITER, RMS_DENSITY_0, RMS_DENSITY_1, RMS_DENSITY_2, RMS_DENSITY_3, RMS_DENSITY_4, RMS_ENERGY, RMS_ENERGY_VE, LIFT, DRAG, TOTAL_HEATFLUX) |
lobb .cfg |
Shape optimizing the tunnel case with energy on | zyao1 | FLUENT | 0 | December 1, 2020 16:05 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 15:53 |
MRFSimpleFoam wind turbine case diverges | ysh1227 | OpenFOAM Running, Solving & CFD | 2 | May 7, 2015 11:13 |
Transient case running with a super computer | microfin | FLUENT | 0 | March 31, 2009 12:20 |
Turbulent Flat Plate Validation Case | Jonas Larsson | Main CFD Forum | 0 | April 2, 2004 11:25 |
