Home > Forums > Software User Forums > SU2
initialization options
Old   September 12, 2024, 03:14
Default initialization options
Giovanni Bettega
gbettega is on a distinguished road
A question for Su2 users.
Let consider the following situation:
1) run N inner loops of a CFD analysis, and with certain
flow initialization options, and save the restart file
2) run a second CFD analysis, using the previosuly saved
restart file, but changing the flow initialization values
Question: the actual flow initialization for the second
run are done using the velocity, pressure, temperature...,
or the new initialization values?
Regards
Giovanni
gbettega is offline   Reply With Quote
Old   September 15, 2024, 17:05
bigfoot
bigfootedrockmidget is on a distinguished road
We get the values for nondimensionalization from the config file, so the new initial values given in the config file will be used even when you are reading the entire initial flow field from file.
bigfootedrockmidget is offline   Reply With Quote
#initialization
Tutorials not working abby10 SU2 Installation 1 December 28, 2021 07:35
UDF: infinite computing after initialization and fluent shutdown fonk Fluent UDF and Scheme Programming 12 April 17, 2020 06:57
finite values inside the simulation domain with hybrid initialization at t =0 sgbaek FLUENT 0 February 15, 2018 19:45
FMG initialization query Mohsin FLUENT 6 November 2, 2016 03:02
Full Multigrid Initialization Mr.Goodcat FLUENT 0 March 17, 2016 07:43
