Home > Forums > Software User Forums > SU2
Saving Data of a Single Point
Old   September 4, 2024, 17:37
Default Saving Data of a Single Point
Ercan Umut
CleverBoy is on a distinguished road
Hello everybody,
I want to save Pressure vs. Time data of a single point in which coordinates are known.
I read some previous entries and saw there was an implementation about point probes but there was no further detail.
In SU2's webpage there is an output option stated as,
VOLUME_OUTPUT= COORDINATES, SOLUTION
but I am not sure if it works since there was no data saved on history.csv or flow.vtu when I open the solution on ParaView.
Is there a way to see the data of a point in an unsteady simulation?
CleverBoy is offline   Reply With Quote
Old   September 4, 2024, 18:38
bigfoot
bigfootedrockmidget is on a distinguished road
Yes, you can use point probes, it is described in the documentation:
https://su2code.github.io/docs_v7/Custom-Output/
you use the keyword CUSTOM_OUTPUT
bigfootedrockmidget is offline   Reply With Quote
Old   September 5, 2024, 13:48
Ercan Umut
Oh yeah, I guess I missed that part It works, thank you.
[General] Export data - point data or vertex data? ansys_matt ParaView 0 May 17, 2021 12:34
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
sample a 3D sub-domain with boundary point data yongxiang OpenFOAM Post-Processing 0 August 22, 2016 08:00
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 15:07
studying a valve case mina.basta OpenFOAM 33 August 30, 2013 05:46
