August 28, 2024, 17:38 |
SU2: pyAMG mesh adaptation issues
Flavio Giannetti
Rep Power: 5 |
Hi guys
for my projects, I decided to try the mesh adaptation capability of SU2. So, I downloaded the "feature_adap" branch which I suppose is the most updated and stable branch for the inria AMG mesh adaptation software and tried to install it. After some trial and error I have been able to compile and install it on my Linux server (Linux Mint 19.1). Then I tried to perform my first SU2 adaptation run. I took the NACA0012 inviscid example and modified the config file adding the AMG options. Here is my configuration file adap_NACA0012.cfg.txt Using the PYADAP_SENSOR= MACH option I was able to perform the Euler simulation of the NACA0012 airfoil in transonic condition with the mesh adaptation. The run was succesfull and returned the updated solution on an adapted mesh. After this attempt, I wanted to try the goal-oriented mesh adaptation (same configuration file but with PYADAP_SENSOR= GOAL). This time I ended up with a segmentation fault. In particular running Code:
mesh_adaptation.py -f adap_NACA0012.cfg -n 12 Code:
SU2-AMG Anisotropic Mesh Adaptation Mesh adaptation options: PYADAP_COMPLEXITY : (6000, 8000, 1000) PYADAP_SUBITE : (2, 2, 2) PYADAP_SENSOR : GOAL PYADAP_HMAX : 200.0 PYADAP_HMIN : 1e-8 PYADAP_ARMAX : 15 PYADAP_HGRAD : 1.3 PYADAP_FLOW_ITER : (500, 700, 900) PYADAP_ADJ_ITER : (500, 700, 900) PYADAP_CFL : (10.0, 15.0, 20.0) PYADAP_RDG : NO ./adap exists. Removing old mesh adaptation in 10s. The ./adap folder was deleted Generating GMF background surface mesh. ## WARNING: MISSING SU2 MESH FILE KEYWORD: NCORNERS=. Running initial CFD solution. Traceback (most recent call last): File "/home/flavio/Software/SU2_AMG/bin/mesh_adaptation.py", line 87, in <module> main() File "/home/flavio/Software/SU2_AMG/bin/mesh_adaptation.py", line 51, in main options.partitions ) File "/home/flavio/Software/SU2_AMG/bin/mesh_adaptation.py", line 77, in mesh_adaptation SU2.run.amg(config) File "/home/flavio/Software/SU2_AMG/bin/SU2/run/amg.py", line 237, in amg SU2_CFD(config_cfd) File "/home/flavio/Software/SU2_AMG/bin/SU2/run/interface.py", line 112, in CFD run_command( the_Command ) File "/home/flavio/Software/SU2_AMG/bin/SU2/run/interface.py", line 292, in run_command raise exception(message) RuntimeError: Path = /home/flavio/Software/SU2_AMG/example_amg/adap/ini/, Command = mpirun -n 12 /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD config_CFD_AD.cfg SU2 process returned error '139' Code:
mpirun -n 12 /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD config_CFD_AD.cfg Code:
------------------------------------------------------------------------- | ___ _ _ ___ | | / __| | | |_ ) Release 7.0.3 "Blackbird" | | \__ \ |_| |/ / | | |___/\___//___| Suite (Computational Fluid Dynamics Code) | | | ------------------------------------------------------------------------- ..... ..... Initialize Jacobian structure (Euler). MG level: 0. Initialize Jacobian structure (Euler). MG level: 1. Initialize Jacobian structure (Euler). MG level: 2. ------------------- Numerics Preprocessing ( Zone 0 ) ------------------- ----------------- Integration Preprocessing ( Zone 0 ) ------------------ ------------------- Iteration Preprocessing ( Zone 0 ) ------------------ Discrete adjoint Euler/Navier-Stokes/RANS fluid iteration. Direct iteration: Euler/Navier-Stokes/RANS equation. Info: Ignoring the following screen output fields: CAUCHY_SENS_PRESS, CAUCHY_DRAG, RMS_ADJ_DENSITY, RMS_ADJ_ENERGY Screen output fields: INNER_ITER, WALL_TIME, RMS_DENSITY, LIFT, DRAG Info: Ignoring the following history output groups: SENSITIVITY History output group(s): ITER, RMS_RES Convergence field(s): RMS_DENSITY Warning: No (valid) fields chosen for time convergence monitoring. Time convergence monitoring inactive. ------------------------------ Begin Solver ----------------------------- Simulation Run using the Single-zone Driver ------------------------------------------------------------------------- Direct iteration to store the primal computational graph. Compute residuals to check the convergence of the direct problem. log10[U(0)]: -8.03383, log10[U(1)]: -5.91761, log10[U(2)]: -5.95849. log10[U(3)]: -2.54363. ------------------------------------------------------------------------- +---------------------------------------------------+ | Inner_Iter| Time(sec)| rms[A_Rho]| rms[A_E]| +---------------------------------------------------+ | 0| 1.3972e-01| -2.915811| -7.783049| | 1| 8.1002e-02| -2.684373| -7.864832| ..... | 495| 2.0795e-02| -7.521627| -12.813194| | 496| 2.0794e-02| -7.530470| -12.821861| | 497| 2.0792e-02| -7.539478| -12.830701| | 498| 2.0791e-02| -7.548650| -12.839715| | 499| 2.0789e-02| -7.557986| -12.848903| Recording the computational graph with respect to the mesh coordinates. ----------------------------- Compute Metric ---------------------------- Computing Hessians using Green-Gauss. Computing flow conservative variable Hessians. Computing adjoint flow variable Hessians. [fd2:115993] *** Process received signal *** [fd2:115993] Signal: Segmentation fault (11) [fd2:115993] Signal code: Address not mapped (1) [fd2:115993] Failing at address: 0x270 [fd2:116027] *** Process received signal *** [fd2:116027] Signal: Segmentation fault (11) [fd2:116027] Signal code: Address not mapped (1) [fd2:116027] Failing at address: 0x270 [fd2:116045] *** Process received signal *** [fd2:116045] Signal: Segmentation fault (11) [fd2:116045] Signal code: Address not mapped (1) [fd2:116045] Failing at address: 0x270 [fd2:116140] *** Process received signal *** [fd2:116140] Signal: Segmentation fault (11) [fd2:116140] Signal code: Address not mapped (1) [fd2:116140] Failing at address: 0x270 [fd2:116172] *** Process received signal *** [fd2:116172] Signal: Segmentation fault (11) [fd2:116172] Signal code: Address not mapped (1) [fd2:116172] Failing at address: 0x270 [fd2:116351] *** Process received signal *** [fd2:116351] Signal: Segmentation fault (11) [fd2:116351] Signal code: Address not mapped (1) [fd2:116351] Failing at address: 0x270 [fd2:116409] *** Process received signal *** [fd2:116409] Signal: Segmentation fault (11) [fd2:116409] Signal code: Address not mapped (1) [fd2:116409] Failing at address: 0x270 [fd2:116466] *** Process received signal *** [fd2:116466] Signal: Segmentation fault (11) [fd2:116466] Signal code: Address not mapped (1) [fd2:116466] Failing at address: 0x270 Computing goal-oriented metric tensor. [fd2:115887] *** Process received signal *** [fd2:115887] Signal: Segmentation fault (11) [fd2:115887] Signal code: Address not mapped (1) [fd2:115887] Failing at address: 0x270 [fd2:115888] *** Process received signal *** [fd2:115888] Signal: Segmentation fault (11) [fd2:115888] Signal code: Address not mapped (1) [fd2:115888] Failing at address: 0x270 [fd2:115889] *** Process received signal *** [fd2:115889] Signal: Segmentation fault (11) [fd2:115889] Signal code: Address not mapped (1) [fd2:115889] Failing at address: 0x270 [fd2:115918] *** Process received signal *** [fd2:115918] Signal: Segmentation fault (11) [fd2:115918] Signal code: Address not mapped (1) [fd2:115918] Failing at address: 0x270 [fd2:115993] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12980)[0x7f0d0ef4d980] [fd2:115993] [ 1] [fd2:115887] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12980)[0x7f033c128980] [fd2:115887] [ 1] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5d2ac4)[0x557a97b2eac4] [fd2:115887] [ 2] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5def52)[0x557a97b3af52] [fd2:115887] [ 3] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x7684fb)[0x557a97cc44fb] [fd2:115887] [ 4] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x75cd62)[0x557a97cb8d62] [fd2:115888] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12980)[0x7fc72a797980] [fd2:115888] [ 1] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5d2ac4)[0x560b759aaac4] [fd2:115888] [ 2] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5def52)[0x560b759b6f52] [fd2:115888] [ 3] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x7684fb)[0x560b75b404fb] [fd2:115888] [ 4] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x[fd2:115889] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12980)[0x7f7d83c56980] [fd2:115889] [ 1] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5d2ac4)[0x56477f319ac4] [fd2:115889] [ 2] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x[fd2:116466] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12980)[0x7f8e7cd5a980] [fd2:116466] [ 1] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5d2ac4)[0x55dcf40c2ac4] [fd2:116466] [ 2] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5def52)[0x55dcf40cef52] [fd2:116466] [ 3] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x7684fb)[0x55dcf42584fb] [fd2:116466] [fd2:115918] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12980)[0x7fc5ce2b7980] [fd2:115918] [ 1] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5d2ac4)[0x55ceee786ac4] [fd2:115918] [ 2] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5def52)[0x55ceee792f52] [fd2:115918] [ 3] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x7684fb)[fd2:116027] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12980)[0x7f91fe413980] [fd2:116027] [ 1] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5d2ac4)[0x555d8371dac4] [fd2:116027] [ 2] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5def52)[0x555d83729f52] [fd2:116027] [ 3] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x7684fb)[0x555d838b34fb] [fd2:116027] [ 4] [fd2:116045] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12980)[0x7f8998665980] [fd2:116045] [ 1] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5d2ac4)[0x5558ec135ac4] [fd2:116045] [ 2] [fd2:116140] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12980)[0x7f187856e980] [fd2:116140] [ 1] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5d2ac4)[0x5654d69f0ac4] [fd2:116140] [ 2] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5def52)[0x5654d69fcf52] [fd2:116140] [ 3] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x7684fb)[0x5654d6b864fb] [fd2:116140] [ 4] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x75cd62)[0x[fd2:116172] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12980)[0x7fd501cbc980] [fd2:116172] [ 1] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5d2ac4)[0x[fd2:116351] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12980)[0x7f32a5ea6980] [fd2:116351] [ 1] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5d2ac4)[0x564cb9cddac4] [fd2:116351] [ 2] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5def52)[0x564cb9ce9f52] [fd2:116351] [ 3] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x7684fb)[0x564cb9e734fb] [fd2:116351] [ 4] [fd2:116409] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12980)[0x7f29b36c0980] [fd2:116409] [ 1] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5d2ac4)[0x55aeef9f4ac4] [fd2:116409] [ 2] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5def52)[0x55aeefa00f52] [fd2:116409] [ 3] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x7684fb/home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5d2ac4)[0x55c1824bfac4] [fd2:115993] [ 2] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5def52)[0x55c1824cbf52] [fd2:115993] [ 3] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x7684fb)[0x55c1826554fb] [fd2:115993] [ 4] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x75cd62)[0x55c182649d62] [fd2:115993] [ 5] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0xc8cd4)[0x55c181fb5cd4] [fd2:115993] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f0d0eb6bc87] [fd2:115993] [ 7] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x1068aa)[0x55c181ff38aa] )[0x55aeefb8a4fb] [fd2:116409] [ 4] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x75cd62)[0x[fd2:115887] [ 5] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0xc8cd4)[0x557a97624cd4] [fd2:115887] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main75cd62)[0x560b75b34d62] [fd2:115888] [ 5] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0xc8cd4)[0x560b754a0cd4] [fd2:115888] [ 6] 5def52)[0x56477f325f52] [fd2:115889] [ 3] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x7684fb)[0x56477f4af4fb] [fd2:115889] [ 4] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x75cd62)[0x56477f4a3d62] [fd2:115889] [ 5] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0xc8cd4)[0x56477ee0fcd4] [ 4] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x75cd62)[0x55dcf424cd62] [fd2:116466] [ 5] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0xc8cd4)[0x55dcf3bb8cd4] [fd2:116466] [ 6] [0x55ceee91c4fb] [fd2:115918] [ 4] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x75cd62)[0x55ceee910d62] [fd2:115918] [ 5] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0xc8cd4)[0x55ceee27ccd4] [fd2:115918] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x75cd62)[0x555d838a7d62] [fd2:116027] [ 5] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0xc8cd4)[0x555d83213cd4] [fd2:116027] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f91fe031c87] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5def52)[0x5558ec141f52] [fd2:116045] [ 3] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x7684fb)[0x5558ec2cb4fb] [fd2:116045] [ 4] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x75cd62)[0x5558ec2bfd62] [fd2:116045] 5654d6b7ad62] [fd2:116140] [ 5] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0xc8cd4)[0x5654d64e6cd4] [fd2:116140] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f187818cc87] [fd2:116140] 55fce06bbac4] [fd2:116172] [ 2] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x5def52)[0x55fce06c7f52] [fd2:116172] [ 3] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x7684fb)[0x55fce08514fb] [fd2:116172] [ 4] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x/home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x75cd62)[0x564cb9e67d62] [fd2:116351] [ 5] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0xc8cd4)[0x564cb97d3cd4] [fd2:116351] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f32a5ac4c87] [fd2:116351] [fd2:115993] *** End of error message *** [ 7] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x1068aa)[0x564cb98118aa] [fd2:116351] *** End of error message *** 55aeefb7ed62] [fd2:116409] [ 5] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0xc8cd4)[0x55aeef4eacd4] [fd2:116409] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f29b32dec87] [fd2:116409] [ 7] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x1068aa)[0x55aeef5288aa] [fd2:116409] *** End of error message *** +0xe7)[0x7f033bd46c87] [fd2:115887] [ 7] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x1068aa)[0x557a976628aa] [fd2:115887] *** End of error message *** /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7fc72a3b5c87] [fd2:115888] [ 7] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x1068aa)[0x560b754de8aa] [fd2:115888] *** End of error message *** [fd2:115889] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f7d83874c87] [fd2:115889] [ 7] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x1068aa)[0x56477ee4d8aa] [fd2:115889] *** End of error message *** /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f8e7c978c87] [fd2:116466] [ 7] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x1068aa)[0x55dcf3bf68aa] [fd2:116466] *** End of error message *** [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7fc5cded5c87] [fd2:115918] [ 7] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x1068aa)[0x55ceee2ba8aa] [fd2:115918] *** End of error message *** [fd2:116027] [ 7] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x1068aa)[0x555d832518aa] [fd2:116027] *** End of error message *** [ 5] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0xc8cd4)[0x5558ebc2bcd4] [fd2:116045] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f8998283c87] [fd2:116045] [ 7] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x1068aa)[0x5558ebc698aa] [fd2:116045] *** End of error message *** [ 7] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x1068aa)[0x5654d65248aa] [fd2:116140] *** End of error message *** 75cd62)[0x55fce0845d62] [fd2:116172] [ 5] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0xc8cd4)[0x55fce01b1cd4] [fd2:116172] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7fd5018dac87] [fd2:116172] [ 7] /home/flavio/Software/SU2_AMG/bin/SU2_CFD_AD(+0x1068aa)[0x55fce01ef8aa] [fd2:116172] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 2 with PID 0 on node fd2 exited on signal 11 (Segmentation fault). -------------------------------------------------------------------------- I am wondering if I did something not correct or specified some wrong option in the config file. Any hints on how to solve the roblem? Is the feature_adap branch the most updated and stable branch for AMG mesh adaptation or I should switch to some other branch ? At the end I would like to replicate the DARPA EquiPS Nozzle problem (mentioned in https://su2code.github.io/documents/su2_dev_alonso.pdf but I am not able to find the configuratiuon fille and the mesh of this example anywhere. Can someone provide a link for such test case? Thanks in advance for the help you can provide Flavio PS I also tried to install the "feat_adap_dev" branch which is based on SU 7.3.1 "Blackbird". I compiled and installed the code without problems but when I run the example in the QuickStart directory Code:
mpirun -np 10 SU2_CFD inv_NACA0012.cfg FILES: adap_NACA0012.cfg.txt mesh_NACA0012_inv.su2.gz log0.txt log1.txt log_dev.txt |
"fetaure_adap" branch, mesh adaptation, pyamg, su2 |
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) | Combas | SU2 | 44 | March 12, 2024 00:35 |
SU2 mesh adaptation branch su2gmf install issue | dlalstnf | SU2 | 0 | May 13, 2023 11:38 |
SU2 coverage issue. Config file or mesh? | zloty001 | SU2 | 3 | December 8, 2019 12:51 |
SU2 Mesh Adaptation Using Adjoint and Gradient-based Methods | Ashkaari | SU2 | 0 | August 28, 2014 05:43 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
