August 26, 2024, 12:14 |
Density stuck at a lower level than expected
Silviu
Rep Power: 2 |
i ran a 2D Single phase Laminar Flat Plate incompressible flow. The basic Laminar Flat plate from tutorials, with a different mesh. same BCs and all.
The density is 1 kg/m3 instead of 1.225 at is supposed to be, which i presume influences the velocity of the flow. The freestream velocity should be 1.16 m/s. Kin Visc is 14.84 m2/s Re 54k flow is laminar I ran it with SOLVER= INC_NAVIER_STOKES and got better results than the original SOLVER= INC_RANS Code:
% ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% % % Physical governing equations (EULER, NAVIER_STOKES, % WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY, % POISSON_EQUATION) SOLVER= INC_NAVIER_STOKES % % If Navier-Stokes, kind of turbulent model (NONE, SA) KIND_TURB_MODEL= NONE % % Mathematical problem (DIRECT, CONTINUOUS_ADJOINT) MATH_PROBLEM= DIRECT % % Restart solution (NO, YES) RESTART_SOL= NO % ---------------- INCOMPRESSIBLE FLOW CONDITION DEFINITION -------------------% % % Initial density for incompressible flows (1.2886 kg/m^3 by default) INC_DENSITY_INIT= 1.225 % % Initial velocity for incompressible flows (1.0,0,0 m/s by default) INC_VELOCITY_INIT= ( 1.16, 0.0, 0.0 ) % % List of inlet types for incompressible flows. List length must % match number of inlet markers. Options: VELOCITY_INLET, PRESSURE_INLET. INC_INLET_TYPE= VELOCITY_INLET % % Damping coefficient for iterative updates at pressure inlets. (0.1 by default) INC_INLET_DAMPING= 0.1 % % List of outlet types for incompressible flows. List length must % match number of outlet markers. Options: PRESSURE_OUTLET, MASS_FLOW_OUTLET INC_OUTLET_TYPE= PRESSURE_OUTLET PRESSURE_OUTLET % % Damping coefficient for iterative updates at mass flow outlets. (0.1 by default) INC_OUTLET_DAMPING= 0.1 % --------------------------- VISCOSITY MODEL ---------------------------------% % % Viscosity model (SUTHERLAND, CONSTANT_VISCOSITY). VISCOSITY_MODEL= CONSTANT_VISCOSITY % % Molecular Viscosity that would be constant (1.716E-5 by default) MU_CONSTANT= 1.48592e-05 ---------------------- REFERENCE VALUE DEFINITION ---------------------------% % % Reference origin for moment computation REF_ORIGIN_MOMENT_X = 0.175 REF_ORIGIN_MOMENT_Y = 0.00 REF_ORIGIN_MOMENT_Z = 0.00 % % Reference length for pitching, rolling, and yawing non-dimensional moment REF_LENGTH= 1.0 % % Reference area for force coefficients (0 implies automatic calculation) REF_AREA= 0.7 % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % % Navier-Stokes wall boundary marker(s) (NONE = no marker) MARKER_HEATFLUX= ( wall, 0.0 ) % % Inlet boundary marker(s) (NONE = no marker) % Format: ( inlet marker, total temperature, total pressure, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) MARKER_INLET= ( inlet, 0, 1.16, 1.0, 0.0, 0.0 ) % % Outlet boundary marker(s) (NONE = no marker) % Format: ( outlet marker, back pressure, ... ) MARKER_OUTLET= ( outlet, 0.0, farfield, 0.0 ) % % Symmetry boundary marker(s) (NONE = no marker) MARKER_SYM= ( symmetry ) % % Marker(s) of the surface to be plotted or designed MARKER_PLOTTING= ( wall ) % % Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluated MARKER_MONITORING= ( wall ) https://ibb.co/0snRd6j https://ibb.co/682PCTj So my question is. why is my density stuck at 1 kg/m3 ? This is my first post so please let me know if i missed anything and thanks in advance guys |
August 28, 2024, 14:24 |
Silviu
Rep Power: 2 |
somebody on reddit said it might show the normalised density.
I think it's wrong because the 0.82 pa pressure difference should produce a free stream velocity of 1.16 m/s and it does not. |
August 28, 2024, 15:55 |
bigfoot
Rep Power: 21 |
The default is to nondimensionalize the results.
You can use dimensionalized values using: Code:
INC_NONDIM = DIMENSIONAL |
August 29, 2024, 14:19 |
update
Silviu
Rep Power: 2 |
so it was actualy nondimensionalised. using this,you can set it to have the actual values : INC_NONDIM = DIMENSIONALINC_NONDIM = DIMENSIONAL the solution proposed by u/kpisagenius i think its actually this one WRT_FORCES_BREAKDOWN=YES which even though it didnt give me a straight answer, it was very helpful in pointing me to why the velocity is wrong, due to having a bigger Re number than expect. |
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 13:16 |
[snappyHexMesh] Snapping issue at cell level change | DGT | OpenFOAM Meshing & Mesh Conversion | 3 | March 14, 2023 08:13 |
[snappyHexMesh] Edge Refinement | fracasce | OpenFOAM Meshing & Mesh Conversion | 3 | December 2, 2017 14:30 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 10:40 |
Problem on high density ratio in Level Set method | Kai Yan | Main CFD Forum | 10 | December 25, 2007 07:12 |
