August 25, 2024, 21:05 |
Surface sensitivity vector is all zeros
Viv Bone
Rep Power: 2 |
I am currently trying to use the adjoint solver to compute the surface sensitivities of a geometry that I have parameterized with an FFD box. When I run the adjoint solver, I expect SU2 to write values for Sensitivity_x, Sensitivity_y, and Surface_Sensitivity to surface_adjoint.csv, however, I obtain non-zero values ONLY for Surface_Sensitivity. My adjoint solution converges correctly. A sample row (with some columns removed) from my surface_adjoint.csv is as follows: Code:
"PointID","x","y","Sensitivity_x","Sensitivity_y","Surface_Sensitivity" 0, 9.997500181200000e-01, -3.632896519016437e-05, 0.000000000000000e+00, 0.000000000000000e+00, -1.474964799476371e+01 How come I am obtaining zeros for Sensitivity_x and Sensitivity_y? I have tried repeating this process on the QuickStart example and also have the same problem. Kind regards. |
August 27, 2024, 00:59 |
Viv Bone
Rep Power: 2 |
Using the discrete adjoint gives the full sensitivity vector.
Is this the only way to obtain the full vector? Thanks |
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points | Simurgh | OpenFOAM Meshing & Mesh Conversion | 4 | August 25, 2023 08:58 |
Surface Sensitivity Vectors | Daaman | SU2 | 3 | May 12, 2022 03:58 |
Sensitivity x,y are zeros | jannav | SU2 Shape Design | 0 | January 31, 2022 09:29 |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 19:28 |
[snappyHexMesh] Add additional boundary layers to complex stl surface | tobijingles | OpenFOAM Meshing & Mesh Conversion | 1 | October 26, 2011 11:45 |
