Converting restart_flow.dat from binary to readable text format |
August 21, 2024, 11:17 |
Anthony Darshan Francis
Hello everyone,
I'm currently working on solving the shock tube problem using SU2. after having run the initial .cfg file for 1 iteration so as to create a initial flow field and produces a restart file in .dat format. I would like to read this .dat file to make further changes to flow, but how do I convert the binary format (garbled text) to text readable format. Thank you |
August 21, 2024, 16:21 |
bigfoot
Rep Power: 21 |
Why do you not save the restart file as ascii data? It will make life much easier for you. Just use RESTART_ASCII as keyword.
August 31, 2024, 19:11 |
na
Rep Power: 8 |
To be a bit more specfic with what you want in your output file (as mr bigfootedrockmidget already mentioned) (and I added the volume paraview output because you might want to look at that too ):
OUTPUT_FILES= RESTART_ASCII, PARAVIEW SU2 can store in human readable ascii format if you want, but binary is the default since it is much more disk-space efficient. Please see the config_template.cfg file in the code root for all available options best, tobi |
How to read OpenFOAM's result in binary format? | Stan Zhou | OpenFOAM Post-Processing | 2 | August 26, 2021 00:17 |
The text comand format for "write-profile" | Mohammad Kazemi | FLUENT | 2 | January 20, 2021 12:49 |
Display-view-read text file?and format? | junz | FLUENT | 0 | October 31, 2014 00:43 |
How to write a binary file readable by tecplot di? | Dong | Tecplot | 5 | October 19, 2006 12:38 |
Error to re-open fluent case file | J.Gimbun | FLUENT | 0 | April 27, 2006 09:42 |
