Home > Forums > Software User Forums > SU2
newbie MPI error out of box on ubuntu
Old   August 16, 2024, 13:03
Default newbie MPI error out of box on ubuntu
cfd77
cfd77 is on a distinguished road
Hi SU2 friends,
I am new to SU2.
I git cloned SU2 from git repository: https://github.com/su2code/SU2
I have also tried SU2 8.0.1
I did
./meson.py build
sudo ./ninja -C build install
When I run
SU2_CFD inv_NACA0012.cfg
in QuickStart folder, I got this error:
*** An error occurred in MPI_Win_create
*** reported by process [3211657217,0]
*** on communicator MPI_COMM_WORLD
*** MPI_ERR_WIN: invalid window
*** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
*** and potentially your MPI job)
Since I did not build with -Dcustom-mpi=true -Dextra-deps=mpich
I assume when I run SU2_CFD mpi will not be involved.
Why am I getting MPI related errors?
How can I run the QuickStart without getting these errors?
Thanks very much!
cfd77 is offline   Reply With Quote
Old   August 18, 2024, 12:02
bigfoot
bigfootedrockmidget is on a distinguished road
Maybe you still compile with mpi.
You can explicitly disable mpi using
Dwith-mpi=false
bigfootedrockmidget is offline   Reply With Quote
Old   August 31, 2024, 19:17
na
TKatt is on a distinguished road
That seems to be a common thing on ubuntu ... i dunno what to really do about it either.
you can use the following which should do the trick (it does for me on all ubuntu systems)
mpirun -n 1 --mca osc ucx SU2_CFD ...
I have that trick/hack from https://github.com/open-mpi/ompi/issues/10726
hope that kinda helps, Tobi
TKatt is offline   Reply With Quote
Old   September 4, 2024, 17:47
Ercan Umut
CleverBoy is on a distinguished road
If you are using Ubuntu 24 which is the latest release, you can try to return Ubuntu 22 or 20. I guess if you don't specify anything SU2 compiles with Dwith-mpi=auto and if there're openmpi and mpich both installed in your computer it creates some problems.
CleverBoy is offline   Reply With Quote
mpi errors
I get different results when I scale the 'falling box' tutorial Hossein1 FLUENT 7 August 19, 2017 03:52
[General] Newbie installing Paraview in Ubuntu 16 completenoob ParaView 5 August 20, 2016 07:25
openfoam-2.3.0 on ubuntu natty 11.04 mickjazz OpenFOAM Installation 1 August 5, 2014 14:01
[DesignModeler] simply model, empty box conquer ANSYS Meshing & Geometry 0 March 28, 2014 19:26
Immersol Simulation of a Heated Box Dong Phoenics 0 March 2, 2006 22:20
