Problem Implementing Internal Surfaces in SU2 |
August 6, 2024, 17:21 |
PA
Rep Power: 7 |
Hello Everyone,
I’m having an issue implementing internal surfaces in SU2. (See attached figures.) I have a simple channel geometry that runs with no issues as expected. However, when I define two internal boundaries, “internal1” and “internal2”, without changing anything else in the simulation, the simulation mysteriously crashes after about 20 or so iterations. This is the marker that I’m using: MARKER_INTERNAL= ( internal1, internal2 ) I’m not sure what I’m doing incorrectly. Can someone please assist me with this? Both meshes, and the .cfg file I’m using along with a few images for reference can be found using the following Dropbox link: https://www.dropbox.com/scl/fo/3zu5m...wabrdftyc&dl=0 Any assistance would be greatly appreciated. The .cfg file I'm using is pasted here for convenience: %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% % % Physical governing equations (EULER, NAVIER_STOKES, % WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY, % POISSON_EQUATION) SOLVER= RANS % % If Navier-Stokes, kind of turbulent model (NONE, SA, SA_NEG, SST) KIND_TURB_MODEL= SST % % Mathematical problem (DIRECT, CONTINUOUS_ADJOINT) MATH_PROBLEM= DIRECT % % Restart solution (NO, YES) RESTART_SOL= NO AXISYMMETRIC= YES CUSTOM_OUTPUTS= 'velocity : Macro{sqrt(pow(VELOCITY_X, 2))};\ avg_vel_in : MassFlowAvg{$velocity}[farfield];\ avg_vel_out : MassFlowAvg{$velocity}[exit]' SCREEN_OUTPUT= INNER_ITER, RMS_DENSITY, LINSOL_RESIDUAL,\ avg_vel_in, avg_vel_out HISTORY_OUTPUT = ITER, AERO_COEFF, FLOW_COEFF, FLOW_COEFF_SURF,CUSTOM, FLUID_MODEL= STANDARD_AIR % -------------------- COMPRESSIBLE FREE-STREAM DEFINITION --------------------% % % Mach number (non-dimensional, based on the free-stream values) MACH_NUMBER= 0.2 % % Angle of attack (degrees, only for compressible flows) AOA= 0.0 % % Side-slip angle (degrees, only for compressible flows) SIDESLIP_ANGLE= 0.0 % % Free-stream pressure (101325.0 N/m^2 by default) FREESTREAM_PRESSURE= 101300.0 % % Free-stream temperature (288.15 K by default) FREESTREAM_TEMPERATURE= 288 MARKER_FAR = ( farfield ) INIT_OPTION= TD_CONDITIONS % ---------------------- REFERENCE VALUE DEFINITION ---------------------------% % % Reference origin for moment computation REF_ORIGIN_MOMENT_X = 0.25 REF_ORIGIN_MOMENT_Y = 0.00 REF_ORIGIN_MOMENT_Z = 0.00 % % Reference length for pitching, rolling, and yawing non-dimensional moment REF_LENGTH= 1.0 % % Reference area for force coefficients (0 implies automatic calculation) REF_AREA= 1.0 % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % MARKER_HEATFLUX= ( wall, 0.0 ) % % Inlet boundary type (TOTAL_CONDITIONS, MASS_FLOW) INLET_TYPE= TOTAL_CONDITIONS %MARKER_INLET= ( farfield, 288.6, 102010.0, 1.0, 0.0, 0.0 ) MARKER_INTERNAL= ( internal1, internal2 ) MARKER_OUTLET= ( exit, 90000 ) % ------------------------ SURFACES IDENTIFICATION ----------------------------% % % Marker(s) of the surface to be plotted or designed MARKER_PLOTTING= ( wall ) % % Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluated MARKER_MONITORING= ( wall ) % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % % Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES) NUM_METHOD_GRAD= GREEN_GAUSS %NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES % % Courant-Friedrichs-Lewy condition of the finest grid CFL_NUMBER= 5 % % Adaptive CFL number (NO, YES) CFL_ADAPT= NO % % Parameters of the adaptive CFL number (factor down, factor up, CFL min value, % CFL max value ) CFL_ADAPT_PARAM= ( 0.1, 2.0, 50.0, 1e10 ) % % Runge-Kutta alpha coefficients RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 ) % % Number of total iterations ITER= 999999 %MUSCL_FLOW= YES % ------------------------ LINEAR SOLVER DEFINITION ---------------------------% % % Linear solver for implicit formulations (BCGSTAB, FGMRES) LINEAR_SOLVER= FGMRES % % Preconditioner of the Krylov linear solver (ILU, JACOBI, LINELET, LU_SGS) LINEAR_SOLVER_PREC= ILU % % Minimum error of the linear solver for implicit formulations LINEAR_SOLVER_ERROR= 1E-10 % % Max number of iterations of the linear solver for the implicit formulation LINEAR_SOLVER_ITER= 20 % -------------------------- MULTIGRID PARAMETERS -----------------------------% % % Multi-Grid Levels (0 = no multi-grid) MGLEVEL= 0 % % Multi-grid cycle (V_CYCLE, W_CYCLE, FULLMG_CYCLE) MGCYCLE= W_CYCLE % % Multi-grid pre-smoothing level MG_PRE_SMOOTH= ( 1, 2, 3, 3 ) % % Multi-grid post-smoothing level MG_POST_SMOOTH= ( 0, 0, 0, 0 ) % % Jacobi implicit smoothing of the correction MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 ) % % Damping factor for the residual restriction MG_DAMP_RESTRICTION= 1.0 % % Damping factor for the correction prolongation MG_DAMP_PROLONGATION= 1.0 % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % % Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC, % TURKEL_PREC, MSW) CONV_NUM_METHOD_FLOW= JST % % 2nd and 4th order artificial dissipation coefficients JST_SENSOR_COEFF= ( 0.5, 0.02 ) % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT) TIME_DISCRE_FLOW= EULER_IMPLICIT % -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------% % % Convective numerical method (SCALAR_UPWIND) CONV_NUM_METHOD_TURB= SCALAR_UPWIND % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the turbulence equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_TURB= NO % % Slope limiter (VENKATAKRISHNAN, MINMOD) SLOPE_LIMITER_TURB= VENKATAKRISHNAN % % Time discretization (EULER_IMPLICIT) TIME_DISCRE_TURB= EULER_IMPLICIT % --------------------------- CONVERGENCE PARAMETERS --------------------------% % % Convergence criteria (CAUCHY, RESIDUAL) CONV_FIELD= RMS_DENSITY % % Min value of the residual (log10 of the residual) CONV_RESIDUAL_MINVAL= -7 % % Start convergence criteria at iteration number CONV_STARTITER= 10 % % Number of elements to apply the criteria CONV_CAUCHY_ELEMS= 100 % % Epsilon to control the series convergence CONV_CAUCHY_EPS= 1E-10 % ------------------------- INPUT/OUTPUT INFORMATION --------------------------% % % Mesh input file MESH_FILENAME= Channel_With_Internal1_Internal2.su2 %MESH_FILENAME= Channel_Without_Internal1_Internal2.su2 % Mesh input file format (SU2, CGNS, NETCDF_ASCII) MESH_FORMAT= SU2 % % Mesh output file MESH_OUT_FILENAME= mesh_out.su2 % % Restart flow input file %SOLUTION_FILENAME= restart_flow10078588.dat % % % Output file format (PARAVIEW, TECPLOT, STL) TABULAR_FORMAT= TECPLOT % % Output file convergence history (w/o extension) CONV_FILENAME= history % % Output file restart flow RESTART_FILENAME= restart_flow.dat % % Output file restart adjoint RESTART_ADJ_FILENAME= restart_adj.dat % % Output file flow (w/o extension) variables VOLUME_FILENAME= flow % % Output file adjoint (w/o extension) variables VOLUME_ADJ_FILENAME= adjoint % % Output objective function gradient (using continuous adjoint) GRAD_OBJFUNC_FILENAME= of_grad.dat % % Output file surface flow coefficient (w/o extension) SURFACE_FILENAME= surface_flow % % Output file surface adjoint coefficient (w/o extension) SURFACE_ADJ_FILENAME= surface_adjoint % |
August 7, 2024, 04:16 |
bigfoot
Rep Power: 18 |
This sounds like a bug, maybe we forgot to disable something in the special case of internal markers.
Could you create a github issue for it? https://github.com/su2code/SU2/issues |
September 13, 2024, 23:34 |
#3 | |
zs
Rep Power: 2 |
I also encountered the same problem, where I took a internal monitoring surface, but it diverged at 200 steps. |
September 17, 2024, 03:26 |
bigfoot
Rep Power: 18 |
Are you using the RANS solver like the OP or another solver? and which version of SU2 are you using?
I did not look into this yet. If you are stuck, and you only need an interface for monitoring purposes, you can in the mean time work with paraview and postprocess the paraview results. Or if you need only point data or data on other existing markers, you can use the macro functionality. |
Yesterday, 08:39 |
#5 | |
zs
Rep Power: 2 |
I want to set an internal cross-section for the optimization objective calculation during the optimization process, such as internal1, which is set in config of MARKER_ANALYZE=(internal1). Before that, we need to solve the flow field. Unfortunately, the calculations have been diverging. |
Tag an internal marker in SU2 | akshaydeshpande | SU2 | 1 | September 2, 2019 13:28 |
Pitching and Plunging problem in SU2 | albinjohny | SU2 Shape Design | 1 | July 5, 2015 01:54 |
[snappyHexMesh] Boundary Patch definition on Thin Surfaces / Internal Walls in SnappyHex | Hannes_Kiel | OpenFOAM Meshing & Mesh Conversion | 4 | August 27, 2013 01:06 |
Can SU2 solve the blast wave problem? | newmancfd | SU2 | 2 | May 13, 2013 03:33 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 08:39 |
