Home > Forums > Software User Forums > SU2
What kind of mesh deformation method is used in SU2?
Old   August 6, 2024, 11:24
Default What kind of mesh deformation method is used in SU2?
denghong
denghong is on a distinguished road
Hello friends:
I am using the SU2 to simulate a pitching airfoil .
And i find the corresponding .cfg file write:
% ----------------------- DYNAMIC MESH DEFINITION -----------------------------%
GRID_MOVEMENT= RIGID_MOTION
MOTION_ORIGIN= (0.25 0.0 0.0)
PITCHING_OMEGA= (0.0 0.0 14.91675)
PITCHING_AMPL= (0.0 0.0 8.0)
Now i want to know what kind of mesh deformation method is used
and how can i edit the corresponding source code about it?
Thanks.
denghong is offline   Reply With Quote
Old   August 19, 2024, 05:36
Giovanni Medici
giovanni.medici is on a distinguished road
Dear denghong,
I'd say that the source code snippet that you provided refers to rigid motion, so basically it is a rigid transformation (in this case a sinusoidal rotation around the MOTION_ORIGIN, with the specified amplitude and omega).
Although, as you are specifying it, it is "pitching" around the Z axis.
giovanni.medici is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 13:38
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
