Problems with Boundary Condition in the config file |
July 26, 2024, 09:35 |
Jimin.Zhang
Rep Power: 2 |
Hello everyone, I am a newcomer to learning SU2. Recently, I have been studying the issue of SU2 handling multi-zone meshes. I have noticed that in the `config_template` (Figure 1), in addition to the need to describe the shared edges between the two zones (MAKER_ZONE_INTERFACE) and the type (MARKER_FLUID_INTERFACE), it also defines what kind of interpolation method to use. However, in the test case (Figure 2), I did not find a description of the interpolation method. Why is that?
July 27, 2024, 17:15 |
California
Rep Power: 7 |
I believe when no KIND_INTERPOLATION is provided the default interpolation is "NEAREST_NEIGHBOR" where the donor is essentially the shortest distance vertex from the receiver.
July 27, 2024, 23:25 |
Jimin.Zhang
Rep Power: 2 |
Thank you for your reply!
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 03:50 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
