Rep Power: 4 ![]() |
Hi all,
I'm new to SU2 and now I'm trying to modify the standard wall function. I know that I can modify the constants such as kappa (von karman constant), B, etc., in the .cfg file. But what I want to do is add terms that include a function of y_plus. For example, u+ = 1/kappa * log(y_plus) + B +f(y_plus) For this reason, I tried to find the source code defining the wall functions but I couldn't found it. Where can I see the exact formula of the wall functions that SU2 uses? Also, is this modification possible in SU2? Thanks. Best regards, |
bigfoot
Rep Power: 17 ![]() |
What is the physics behind it? Is it for rough walls?
You can see the implementation for the incompressible solver in: CIncNSSolver::Set_Tau_Wall_WF The implementation is based on the paper of Nichols and Nelson: https://arc.aiaa.org/doi/abs/10.2514/1.3539 You can see there that the wall function is implemented implicitly, so we have y+(u+) given by Spalding's formula. Hope this helps. For more coding help, you can also consider joining our slack channel.If you go to our main website, just click the "Dev Team Slack" option. https://su2code.github.io/ |
Wall functions vs. Solving viscous layer | TommyM | OpenFOAM Pre-Processing | 0 | April 28, 2020 17:14 |
Enhanced Wall Treatment | paduchev | FLUENT | 24 | January 8, 2018 11:55 |
How are Wall Functions Practically Implemented! | pche8701 | Main CFD Forum | 2 | June 2, 2016 10:58 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
wall functions implementation | besh | OpenFOAM Programming & Development | 0 | January 1, 2013 09:14 |
