Giovanni Bettega
Rep Power: 11 ![]() |
hello forum,
the two lines CONV_FIELD= RMS_PRESSURE CONV_RESIDUAL_MINVAL= -4 set the convergence level to 10^-4 for RMS pressure. Instead, do the two lines CONV_FIELD= RMS_PRESSURE, RMS_VELOCITY-X CONV_RESIDUAL_MINVAL= -4 set the convergence level to 10^-4 for both RMS pressure and velocity-x? I think so. Last: do the two lines CONV_FIELD= RMS_PRESSURE, RMS_VELOCITY-X CONV_RESIDUAL_MINVAL= -4,-5 set TWO different convergence levels for RMS pressure and density? If yes, does the solver stop ONLY when the two levels have been reached? In summary: is it possible to set a different level of convergence for each one of the defined convergence fields? Or it is only possible to define a unique convergence limit for each one of the defined fields? Thank you for your help Giovanni Last edited by gbettega; June 28, 2024 at 13:13. |
convergence check |
[snappyHexMesh] Sharp corners advice | jvinuales | OpenFOAM Meshing & Mesh Conversion | 4 | October 18, 2022 07:43 |
Floating point exception error when rotate the geometry | zyfsoton | OpenFOAM Running, Solving & CFD | 1 | June 20, 2022 05:49 |
[snappyHexMesh] SHM Bad quality snapping/terracing | ryan55510 | OpenFOAM Meshing & Mesh Conversion | 0 | April 20, 2022 20:20 |
[snappyHexMesh] SHM error: inside mesh not possible | Naresh yathuru | OpenFOAM Meshing & Mesh Conversion | 1 | January 10, 2017 23:58 |
Convergence problem residuals stay at a certain level | andimb | OpenFOAM Running, Solving & CFD | 3 | April 28, 2006 17:13 |
