June 19, 2024, 07:46 |
NEMO-SST Run Error
Ercan Umut
Rep Power: 3 |
Hello everybody,
I am trying to run a hypersonic case using Code:
SOLVER= NEMO_NAVIER_STOKES KIND_TURB_MODEL= SST Code:
Simulation Run using the Single-zone Driver [ercan:11791] *** Process received signal *** [ercan:11791] Signal: Segmentation fault (11) [ercan:11791] Signal code: Address not mapped (1) [ercan:11791] Failing at address: (nil) [ercan:11792] *** Process received signal *** [ercan:11792] Signal: Segmentation fault (11) [ercan:11792] Signal code: Address not mapped (1) [ercan:11792] Failing at address: (nil) [ercan:11792] [ 0] [ercan:11793] *** Process received signal *** [ercan:11793] Signal: Segmentation fault (11) [ercan:11793] Signal code: Address not mapped (1) [ercan:11793] Failing at address: (nil) [ercan:11793] [ 0] [ercan:11794] *** Process received signal *** [ercan:11794] Signal: Segmentation fault (11) [ercan:11794] Signal code: Address not mapped (1) [ercan:11794] Failing at address: (nil) [ercan:11794] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x43090)[0x7f20209f5090] [ercan:11794] [ 1] SU2_CFD(+0x221754)[0x561595e28754] [ercan:11794] [ 2] SU2_CFD(+0x21f9ae)[0x561595e269ae] [ercan:11794] [ 3] [ercan:11791] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x43090)[0x7fb708ad5090] [ercan:11791] [ 1] SU2_CFD(+0x221754)[0x55a1b7960754] [ercan:11791] [ 2] SU2_CFD(+0x21f9ae)[0x55a1b795e9ae] [ercan:11791] [ 3] SU2_CFD(+0x1f7bdb)[0x55a1b7936bdb] [ercan:11791] [ 4] SU2_CFD(+0x1f7bdb)[0x561595dfebdb] [ercan:11794] [ 4] /lib/x86_64-linux-gnu/libc.so.6(+0x43090)[0x7fc6476bc090] [ercan:11792] [ 1] SU2_CFD(+0x221754)[0x55eb5a5ec754] [ercan:11792] [ 2] SU2_CFD(+0x21f9ae)[0x55eb5a5ea9ae] [ercan:11792] [ 3] SU2_CFD(+0x1f7bdb)[0x55eb5a5c2bdb] [ercan:11792] [ 4] SU2_CFD(+0x158a5d)[0x55eb5a523a5d] [ercan:11792] [ 5] /lib/x86_64-linux-gnu/libc.so.6(+0x43090)[0x7f5709a9c090] [ercan:11793] [ 1] SU2_CFD(+0x221754)[0x55e48c46d754] [ercan:11793] [ 2] SU2_CFD(+0x21f9ae)[0x55e48c46b9ae] [ercan:11793] [ 3] SU2_CFD(+0x1f7bdb)[0x55e48c443bdb] [ercan:11793] [ 4] SU2_CFD(+0x158a5d)[0x55e48c3a4a5d] [ercan:11793] [ 5] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7f5709a7d083] [ercan:11793] [ 6] SU2_CFD(+0x17a31e)[0x55e48c3c631e] [ercan:11793] *** End of error message *** SU2_CFD(+0x158a5d)[0x55a1b7897a5d] [ercan:11791] [ 5] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7fb708ab6083] [ercan:11791] [ 6] SU2_CFD(+0x17a31e)[0x55a1b78b931e] [ercan:11791] *** End of error message *** SU2_CFD(+0x158a5d)[0x561595d5fa5d] [ercan:11794] [ 5] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7f20209d6083] [ercan:11794] [ 6] SU2_CFD(+0x17a31e)[0x561595d8131e] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7fc64769d083] [ercan:11792] [ 6] SU2_CFD(+0x17a31e)[0x55eb5a54531e] [ercan:11792] *** End of error message *** [ercan:11794] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun noticed that process rank 1 with PID 0 on node ercan exited on signal 11 (Segmentation fault). |
Gmsh reports an OpenCascade exception when opening a .geo file | algc | Main CFD Forum | 2 | October 24, 2022 05:59 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
