Home > Forums > Software User Forums > SU2
How to create .dat file
Old   June 17, 2024, 07:20
Question How to create .dat file
Tianmin Li
dlyltm is on a distinguished road
A element_properties.dat file is used in part "Non-linear Elasticity with Multiple Materials". How was the above .dat file created and what tool was used?
dlyltm is offline   Reply With Quote
Old   June 17, 2024, 16:38
bigfoot
bigfootedrockmidget is on a distinguished road
You can use any tool you want, it is a simply ASCII file.
bigfootedrockmidget is offline   Reply With Quote
Old   June 17, 2024, 22:27
Tianmin Li
@bigfootedrockmidget Thanks. But in part "Constrained shape design of a transonic turbulent airfoil at a cte. CL", there're solution_flow.dat, solution_adj_cd.dat, and solution_adj_cmz.dat and they aren't ASCII files. Then what tools were used to generate them?
Old   June 18, 2024, 07:29
bigfoot
So the other .dat files are the solutions that come out of SU2, solution.dat contains the CFD results and solution_adj_x.dat contains the adjoint results for x.
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
