Tianmin Li
Rep Power: 2 ![]() |
How to create .su2 file? Is it all created manually with text edit?
Additionally, how to create .cgns file? It seems not a text file. |
bigfoot
Rep Power: 17 ![]() |
You can create a mesh yourself with python if it is a simple mesh, or you could use meshing software. gmsh is free to use, and good to start with. It can also save meshes directly in su2 format.
Tianmin Li
As far as I know, gmsh itself cannot directly generate CGNS files. How about Pointwise and Gridgen?
.su2 |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
