Giovanni Bettega
Rep Power: 11 ![]() |
A steady state run: TIME_DOMAIN=NO (only inner loops) There is and option in the configuration file: TIME_DISCRE_FLOW which can be 1) EULER_IMPLICIT 2) EULER_EXPLICIT 3) RUNGE_KUTTA_EXPLICIT (In the config template I found % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT) TIME_DISCRE_FLOW= EULER_IMPLICIT ) About the explicit options, and in particular about the option 2), is there the possibility of setting directly a "time step" for that explicit approach? Or the "time step" is always local, based on CFL number? Thanks a lot Giovanni Last edited by gbettega; June 12, 2024 at 10:42. |
bigfoot
Rep Power: 17 ![]() |
We have some examples of unsteady simulations in the testcases folder, for instance the flow a square cylinder in TestCases/Unsteady/square_cylinder, you basically do:
TIME_DOMAIN = YES TIME_MARCHING= DUAL_TIME_STEPPING-2ND_ORDER TIME_STEP= 0.0015 MAX_TIME= 3.75 % 2500 iterations - 3.75 % 3500 iterations - 5.25 % 5000 iterations - 7.50 % INNER_ITER= 10 |
Giovanni Bettega
Thanks
my question was about a steady state run Giovanni |
steady state run, time advancement |
Constant steady state temperature | Niels V | CFX | 4 | November 21, 2020 16:16 |
Will the results of steady state solver and transient solver be same? | carye | OpenFOAM Running, Solving & CFD | 9 | December 28, 2019 05:21 |
The difference between steady state and transient | JuPa | CFX | 36 | December 9, 2019 22:50 |
How to run InterFoam in steay state | waynezw0618 | OpenFOAM Running, Solving & CFD | 0 | November 10, 2008 07:08 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
