Home > Forums > Software User Forums > SU2
Time varying Inlet BC in SU2
Old   June 2, 2024, 07:58
Post Time varying Inlet BC in SU2
Alessandro
argix is on a distinguished road
Hi everyone,
I am studying a case of jet impingement on a wall with a time-varying flow at the inlet. I have used compressible RANS and TOTAL_CONDITIONS as inlet BC. Specifically, I have set a time-varying stagnation pressure at inlet.
To do this, I used this Python script http://github.com/su2code/SU2/tree/m...e_unsteady_CHT, modifying some commands to suit my problem. I should mention that I do not use Python frequently, so there are likely some errors. Indeed, I checked the documentation and noticed that the command I used to vary the pressure at the inlet (SetMarkerCustomPtotal) is not listed.
However, when I run the simulation, it seems to work quite well. Unfortunately, when examining the pressure field, it appears that the time-varying boundary conditions are applied on the walls with no-slip conditions (represented by the MARKER_ISOTHERMAL command) and not at the inlet as I want.
Could you please tell me what changes I need to make in the Python script to correctly set up the problem? For completeness, I am attaching the script I modified, the configuration file, and a video of the pressure field.
https://github.com/user-attachments/...unsteady_5.zip
Thank you in advance for your help.
Best Regards.
argix is offline   Reply With Quote
Old   June 2, 2024, 19:31
bigfoot
bigfootedrockmidget is on a distinguished road
We do not have setmarkercustomPTotal, so this will not work as intended.
We currently do not even have python customizable inlets it seems. What you could do is have a look at the implementation of SetMarkerCustomTemperature and SetCustomBoundaryTemperature and implement something similar in the inlet boundary condition in the euler solver CEulerSolver::BC_Inlet
OK, I see you also posted this on github, and pcarruscag is on the case, so it should be implemented in 5,4,3,2,...
bigfootedrockmidget is offline   Reply With Quote
custom bc, su2, time varying inlet bc.
[OLAFLOW] The OLAFLOW Thread Phicau OpenFOAM Community Contributions 459 September 12, 2024 12:47
How to generate Time varying Inlet velocity with a particular profile faiazk OpenFOAM Pre-Processing 15 June 3, 2021 07:16
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores puneet336 OpenFOAM Running, Solving & CFD 11 April 7, 2019 01:58
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
