Help with Conjugate Heat Transfer Simulation in Converging-Diverging Duct |
Sean
Rep Power: 3 ![]() |
I am currently working on a simulation project involving conjugate heat transfer in a converging-diverging duct, and I am looking for some guidance on how to set it up properly in SU2.
Here are the specifics of my problem: Geometry: The duct has a converging-diverging shape with specified inlet and outlet dimensions. Flow Conditions: I'm dealing with a compressible flow, with known inlet and outlet conditions. Heat Transfer: I need to account for both convective and conductive heat transfer within the solid walls and the fluid. Mesh Generation: I created mesh for both the domains and then concatenated the mesh into one single file. Could you please provide some insights or steps on the following: Boundary Conditions: Suggestions for applying appropriate boundary conditions for both the fluid and solid regions. Any help or pointers on this topic would be greatly appreciated! Thank you in advance for your support. Best regards |
cht, conjugate heat transfer, heat tranfer |
Calculating heat ballance in transient simulation | karachun | CFX | 6 | January 28, 2022 02:23 |
Convergence in a conjugate heat transfer problem | Mohamed Abdulazim | FLUENT | 5 | March 28, 2020 15:41 |
whether to use Shell conduction or Conjugate heat transfer model in Fluent | Dilu | CFD Freelancers | 1 | March 3, 2020 21:42 |
Conjugate Heat Transfer simulation of AFPM electric generator | AlexRonto | CFD Freelancers | 4 | September 18, 2017 03:23 |
Setup of a turbine stator blade conjugate heat transfer simulation | mitra22 | CFX | 0 | February 7, 2014 04:53 |
