Angle of attack design variable, compute adjoint |
May 22, 2024, 11:09 |
Francois Gallard
Rep Power: 16 |
I would like to compute the gradient of lift and drag with respect to the angle of attack. I tried to simplify the config file, and came back to the NACA12 use case and set: DV_KIND= ANGLE_OF_ATTACK DV_MARKER= ( airfoil ) DV_PARAM= 1. DV_VALUE= 10.0 DEFINITION_DV= (101, 1.0 | airfoil | 1.0) But these seem to have no effect: the lift is null and the gradient of lift and drag with respect to the design variables is null too in of_grad_cd.csv and of_grad_cl.csv When using SCREEN_OUTPUT= (SENS_AOA), I see it is computed somewhere but I cant get it in the gradient. Is this doable? Thanks François |
Analysis of angle of attack vs lift generated | vikhattangady | FLUENT | 0 | October 31, 2013 04:42 |
[OpenFOAM] Plot Angle of Attack Next to Transient Pitching Airfoil | dancfd | ParaView | 6 | October 24, 2013 00:37 |
Suggestions required for modelling vortex generator with variable angle of attack | Crank-Shaft | ANSYS | 1 | January 4, 2013 22:31 |
introducing angle of attack on ICEMCFD HEXA | icem beginner | FLUENT | 2 | December 6, 2008 15:34 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
