Simulating Slip Flow Over a Cylinder Using SU2 for Verification and Validation |
Sean
Rep Power: 3 ![]() |
Hello SU2 community,
I’m interested in simulating slip flow over a cylinder using the SU2 framework. Specifically, I want to replicate the case described in the paper “SU2-NEMO: An Open-Source Framework for High-Mach Nonequilibrium Multi-Species Flows” to verify and validate my results. Could you please guide me on how to set up this case in SU2? What parameters should I consider for slip flow simulations ? Any insights, best practices, or relevant examples related to this specific case would be greatly appreciated! Thank you in advance for your help! Best regards |
#2 | |
Sean
nemo |
Simulating Flow Over a Cylinder with Catalytic Wall in SU2 | bgulzar22 | SU2 | 0 | May 10, 2024 09:04 |
Validation using flow around Cylinder | Josesilva | OpenFOAM Verification & Validation | 1 | April 11, 2019 17:11 |
Validation using flow around Cylinder | CXI | OpenFOAM Running, Solving & CFD | 3 | November 17, 2015 05:30 |
Validation of Flow Around a Cylinder in STAR and Pheonics | Tycoon | Main CFD Forum | 2 | November 23, 2012 09:05 |
Oscillating flow around cylinder validation error | Zak | FLUENT | 0 | September 22, 2005 16:09 |
