Home > Forums > Software User Forums > SU2
Flow Converges for AOA 0 1 and 2 but when i increase to 5 or above it diverges
Old   May 9, 2024, 16:57
Default Flow Converges for AOA 0 1 and 2 but when i increase to 5 or above it diverges
Jacob Keddy
JacobKeddy is on a distinguished road
Hi i'm very new to cfd and have spent a few months developing my knowledge and skills for my uni coursework. I need to analyse a NACA airfoil (1412) and am struggling with getting my data to converge.
the config file titled workingT3.cfg in the repository below accurately converges for low AOA (0,1,2) but when i increase to 5 or above my lift and drag coefficients start spiraling out of control.
if anyone could help it would be greatly appreciated.
I have attached a link to my config file (workingT3.cfg) my mesh (farfieldonly.su2) as well as the code used to generate the mesh using gmsh (n1412.geo for geometry and modified.geo for the mesh) I believe my mesh is accurate so shouldnt be a problem there but any advice would be amazing.
I have also attached my Data from xfoil for expected cl and cd values for each angle of attack.
https://github.com/JacobKeddy/SU2-NACA
Thank you,
Jacob
JacobKeddy is offline   Reply With Quote
Old   May 10, 2024, 10:37
bigfoot
bigfootedrockmidget is on a distinguished road
How well does your simulation converge?
Have a look at this page:
https://turbmodels.larc.nasa.gov/air...verif500c.html
Here, the farfield is 500 cord lengths away from the airfoil.
Also check the density of the mesh around the airfoil. These mesh settings will influence your results a lot.
bigfootedrockmidget is offline   Reply With Quote
Old   May 10, 2024, 10:45
Jacob Keddy
Thank you so much for your reply i will try separating the farfield from the airfoil because at the minute it is coincident.
Do you know what i should specify the area between the airfoil and the farfield as because when i initially tried this there was an error with an undefined surface between the new far field and the airfoil.
My mesh converges around the airfoil and is much denser around the airfoil than further into the farfield. I will try increasing the density as well.
Thank you so much again
Jacob
config files, converge error, naca, su2
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Increase in flow rate decrease in Outlet pressure. trovilb1 System Analysis 1 December 5, 2017 08:22
Exit Corrected Mass Flow Rate Mesh Sensitivity Study s__s__s CFX 4 July 20, 2016 12:46
converges first then starts to diverges! why? nenazarian FLUENT 1 April 19, 2012 05:07
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
