Home > Forums > Software User Forums > SU2
Supersonic inlet profile
Old   May 4, 2024, 04:04
Default Supersonic inlet profile
fatgiraffe is on a distinguished road
Hi all,
Is it possible to specify an inlet profile for a supersonic flow in SU2? I've tried both a mass flow inlet and total conditions inlet and my simulation just diverges instantly
fatgiraffe is offline   Reply With Quote
Old   May 4, 2024, 18:11
bigfoot
bigfootedrockmidget is on a distinguished road
Is this specifically when using an inlet profile from a file? It converges with constant inflow conditions? Do you have a small example testcase?
bigfootedrockmidget is offline   Reply With Quote
Old   May 4, 2024, 18:36
Yes, I meant when specifying an inlet profile from a file. I have tried it with uniform inlet conditions and it runs fine, but I'd like to impose an inlet profile if possible. I've tried MARKER_INLET and MARKER_SUPERSONIC_INLET; using the former it diverges instantly and the latter converges but doesn't use the inlet profile from the file.
Old   May 5, 2024, 11:52
bigfoot
I checked the implementation and support for inlet profiles is currently not implemented for supersonic inlets.
You might be able to get this working if you modify the BC_Supersonic_Inlet implementation using the inlet profile implementation of BC_Inlet (in CEulerSolver.cpp) and recompile.
Old   May 7, 2024, 05:23
Shukai Wang
LunarKing1110 is on a distinguished road
Hi, I also have the same question. lmk if you make any progress to the modification. thanks!
LunarKing1110 is offline   Reply With Quote
Old   May 7, 2024, 09:51
bigfoot
Please make a bug report / feature request for it on github.
Old   May 7, 2024, 10:59
Shukai Wang
Hi, I made a feature request for this issue. Really hope you guys can help work on this soon!
Thanks a lot!
https://github.com/su2code/SU2/issues/2275
inlet profile, supersonic inlet
Problems with Viscous Simulation for Supersonic Aircraft Inlet BarisBicakci SU2 2 December 22, 2021 09:09
UDF Velocity profile at inlet aar007 Fluent UDF and Scheme Programming 1 June 28, 2020 23:43
Pressure profile in Velocity inlet Pertica FLUENT 3 June 15, 2020 09:30
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 05:58
Half parabolic profile for the velocity inlet adele FLUENT 4 July 19, 2012 12:43
