Seeking Assistance with SU2 Simulation Implementation |
March 28, 2024, 06:17 |
Sean
Rep Power: 3 |
Dear SU2 Community,
I am currently working on implementing a simulation using SU2 and have encountered a challenge that I hope some of you might be able to assist with. Below is a brief overview of my problem: Problem Overview: I am working on a simulation that involves setting custom temperature boundary condition on a specific marker using Python scripting. However, I'm facing difficulties in properly setting this boundary condition based on temperature data from an external file. I have written a Python script to read the temperature data, assign it to the appropriate marker, and run the simulation. However, despite my efforts, I am encountering issues with the implementation. To provide more context and allow for a better understanding of the problem, I have prepared a comprehensive package containing the following: Configuration file Mesh file Temperature data file Python script for setting the boundary condition and running the simulation You can access the files package through this link:https://drive.google.com/drive/folde...usp=drive_link Request for Assistance: I am reaching out to the SU2 community in the hopes that someone with expertise in Python scripting for SU2 simulations can review my implementation and provide insights into resolving the issues I'm facing. Specifically, I would greatly appreciate any guidance or suggestions on how to properly set the custom temperature boundary conditions using Python scripting. If anyone is willing to lend their expertise and offer assistance, I would be extremely grateful. Your support would not only help me overcome this obstacle but also contribute to advancing my understanding and proficiency in utilizing SU2 for my simulations. Thank you in advance for your time and assistance. Best regards, |
March 28, 2024, 11:52 |
bigfoot
Rep Power: 21 |
I haven't looked at your setup, but the way I would have done it is take this case as a starting point:
https://github.com/su2code/SU2/blob/...T_FlatPlate.py Then change the time-dependent temperature BC for a spatially dependent BC using something like this: Code:
marker_coords = driver.MarkerCoordinates(marker_id) x = marker_coords(i_vertex, 0) y = marker_coords(i_vertex, 1) temperature = temperature_function(x,y) |
March 28, 2024, 16:13 |
bigfoot
Rep Power: 21 |
It looks like you are doing something similar so first take take the working testcase from the repository, verify that it works, then modify it so it uses spatially varying temperature. Just T=x+y or something simple like that. Then get temperature from a file. Verify all intermediate steps.
March 29, 2024, 05:17 |
#4 | |
Sean
Rep Power: 3 |
March 29, 2024, 06:19 |
bigfoot
Rep Power: 21 |
Does your code run fine when you just set temperature=300 in your python script?
Does your code run fine when you set temperature=300+x+y ? |
March 29, 2024, 06:24 |
Sean
Rep Power: 3 |
No, I get the same segmentation error when I run the python script, but when I run the simulation without the python script , it runs fine with isothermal boundary condition.
March 29, 2024, 08:43 |
#7 | |
Sean
Rep Power: 3 |
but I am not sure if it is using temperature distribution correctly. As in my simulation I have given temperature at WALL as 421K(ISOTHERMAL BC). Could you suggest me a way, so that I can check whether the updated temperature distribution is applied on the WALL. Thank YOU in advance. |
cht coupling, cht problem, python script, python script error, python wrapper |
SU2 Supersonic Cascade Simulation: Inlet Boundary Condition Issues | nirvananas314 | SU2 | 4 | March 15, 2024 10:13 |
Seeking Surface Heat Flux Validation for SU2 | bgulzar22 | SU2 | 0 | November 25, 2023 23:09 |
Help Needed: Rocket Nozzle Erosion Simulation Using SU2 | bgulzar22 | SU2 | 2 | August 28, 2023 09:06 |
Making Sure SU2 reads the restart_flow.dat to restart a simulation | pro_ | SU2 | 0 | April 10, 2020 06:44 |
Engine simulation (seeking help with method to use) | Geoff Rathbun | Main CFD Forum | 4 | April 13, 1999 15:19 |
