Home > Forums > Software User Forums > SU2
Can't find SU2_CFD_AD and SU2_DOT_AD
Like Tree1Likes
Old   April 1, 2024, 17:01
cristopher_morales is on a distinguished road
Originally Posted by David_002 View Post
Dear Cristopher.
I've followed the steps you mentioned and try to run the example shown in: https://su2code.github.io/tutorials/...ained_RAE2822/
However, when running:
shape_optimization.py -g DISCRETE_ADJOINT -o SLSQP -f turb_SA_RAE2822.cfg
This is the error it says (see picture). It looks like it is unable to find the SU2_CFD_AD, however i can find it in the folder (see picture). Should this location be added to the nano .basrhc in some way? Could it be any other error?
Once again, thank you for your time and help.
Hi David,
I think there is an error with your PATH, when you run shape_optimization.py, it tries to find SU2_CFD_AD in the directory usr/local/bin/SU2_CFD_AD but the SU2_CFD_AD is intalled in the directory that you show in the second picture, so you should change the PATH in the shape_optimization.py to the PATH where your SU2_CFD_AD is located (second image)
best regards,
Cristopher Morales Ubal
cristopher_morales is offline   Reply With Quote
Old   April 1, 2024, 17:58
David_002 is on a distinguished road
Hi Cristopher,
I'm unable to find where to add the path in the file, Could you indicate where from the pictures attached?
Thank you very much.
David_002 is offline   Reply With Quote
cfd, su2, tools
