January 9, 2024, 09:46 |
Could not find the keyword "NMARK=".
Peter Lysdahl Bęk
Rep Power: 4 |
Hello
I am trying to generate my first mesh for SU2 through gmsh and have reached the following error. Error in "bool CSU2ASCIIMeshReaderFVM::ReadMetadata(bool, CConfig*)": ------------------------------------------------------------------------- Could not find the keyword "NMARK=". Check the SU2 ASCII file format. ------------------------------ Error Exit ------------------------------- I have exported my mesh as su2 where I attained the following error Mismatch between NPOIN and number of points listed in mesh file. Please check the mesh file for correctness. which I solved by deleting my center point for my sphere in the mesh file. Does anyone know how to handle my error with NMARK? (NMARK is present in the file so I do not see the problem) Here is my .geo file from gmsh. -------------------------------------------------------------------------------------- // Gmsh project created on Tue Jan 09 14:52:39 2024 SetFactory("OpenCASCADE"); //+ Point(0) = {0, -0, 0, 1.0}; Point(1) = {-0.1524, -0, 0, 1.0}; Point(2) = {0,0.1524,0,1.0}; Point(3) = {-0.3,0,0,1.0}; Point(4) = {0,0.3,0,1.0}; Point(5) = {0,0,0,1.0}; Line(1) = {1,3}; Line(2) = {2,4}; Circle(3) = {1, 0, 2}; //+ Circle(4) = {3, 0, 4}; //+ Curve Loop(1) = {4, -2, -3, 1}; //+ Plane Surface(1) = {1}; //+ Transfinite Curve {3, 4} = 150 Using Progression 1; //+ Transfinite Curve {1, 2} = 60 Using Progression 1.05; //+ Transfinite Surface {1}; //+ //+ Extrude {0, 0, 0.01} { Surface{1}; Layers {1}; Recombine; } //+ Transfinite Volume{1}; //+ Physical Surface("Wall", 13) = {4}; //+//+ Physical Surface("symmetry", 15) = {5}; //+ Physical Surface("Exit", 16) = {3}; //+ Physical Surface("Inlet", 14) = {2}; -------------------------------------------------------------------------------------- Best. Peter |
January 10, 2024, 17:05 |
bigfoot
Rep Power: 18 |
Do you really need an extruded 3D mesh with one cell in the z-direction?
If so, you also need to define a volume or else you will only have surface meshes (and no mesh in the .su2 file). |
January 11, 2024, 05:25 |
Peter Lysdahl Bęk
Rep Power: 4 |
Thanks for the reply.
I will in the future investigate more complex cases where extrude is needed which is why I am interested in this simple 3D case. I have added a physical volume "Physical Volume("inside", 18) = {1};" However I get the exact same error |
January 14, 2024, 14:45 |
bigfoot
Rep Power: 18 |
You need to add the geometric volume as well as the physical marker: Code:
//+ Physical Volume("interior", 27) = {1}; //+ Volume(2) = {1}; //+ Recombine Surface "*"; Also be aware that there is a bug in an older version of gmsh where all interior points are saved as a marker (4.11.1 had this) |
[Salome] Salome import "Cannot find file "points" in directory..." | mismichael | OpenFOAM Meshing & Mesh Conversion | 6 | June 24, 2024 03:17 |
How to make a code parallel? | Bruno Machado | Fluent UDF and Scheme Programming | 15 | May 27, 2016 09:18 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
Problem Building OF on Centos cluster (no admin rights) | CKH | OpenFOAM Installation | 5 | November 13, 2011 06:32 |
